Stealth CAI installed. - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-29-2014, 12:14 AM   #31
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
What I Drive: chcl gry 02 ZX3 - 5sp
Points 6,185, Level 51
Points: 6,185, Level: 51 Points: 6,185, Level: 51 Points: 6,185, Level: 51
Level Up 18% Completed
Forum Activity 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
Buy-Sell-Trade Rating: (18)
Originally Posted by GreySkorpion View Post
Its 100% your pcv/hose, bite the bullet man!
I hvent found it yet. I think its under my intake manifold......
"You are a person, No one can forget you, even if it's Good or Bad, you make waves!" #truth #truthinadvertizing...
R.I.P. Pat :-( HN #68 - FTO #008 - principal defensor para el diablo
daspazzZX3 is online now
Old 01-29-2014, 12:17 AM   #32
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
I havent found it yet. I think its under my intake manifold......
Old 01-30-2014, 01:50 AM   #33
Graves
Fan#: 39724
What I Drive: 2005 Yellow ZX3 5spd
Points 345, Level 6
Points: 345, Level: 6 Points: 345, Level: 6 Points: 345, Level: 6
Level Up 90% Completed
FF Reputation: 1 Graves Good Standing Member
Does it stumble and die at times?
Graves is offline
Old 01-31-2014, 12:15 AM   #34
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Level Up 38% Completed
Of course its under your intake manifold....didn't you already know that? By now you have to be tired of your car not running correctly............
GreySkorpion is offline
Old 01-31-2014, 12:45 AM   #35
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
The illusive PCV beastie
@ graves, not so much stumble, but sometimes it will die when Im stopping for lights.
@ greyskorpion, actually the damn thing runs great. Im just not getting the gas milage I used to. I had no idea it was under there until today. Did a google search and found many pics showing it under there. Even found a link back to FF on how to do it. .....i will be going south to my mechanic buddys, then I see how hard it is to remove the IM......... I see manual labor in my immediate future.
hell I need to become more intimate with Pats heart anywaays.......
I really do appreciate all the help and eduction you have graciously shared with my d00ffuz 0ld arse.
You guys RAWX!!!
Pic
Old 02-03-2014, 06:28 PM   #36
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
Exclamation Now im bery bery confused
0K so what is this?
Oriely's says this is what I need..................
Old 02-03-2014, 08:09 PM   #37
Elder
Points 13,402, Level 75
Points: 13,402, Level: 75 Points: 13,402, Level: 75 Points: 13,402, Level: 75
Looks like the other end of the PCV system, the hose from the intake TO the Head.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-03-2014, 09:44 PM   #38
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
Ohhhh OK thanks Sailor, You ROCK as usual!
Old 02-07-2014, 01:43 AM   #39
Fangren
Fan#: 100337
What I Drive: 2003 Black Centennial ZTS 2.3l MTX
Points 295, Level 5
Points: 295, Level: 5 Points: 295, Level: 5 Points: 295, Level: 5
FF Reputation: 1 Fangren Good Standing Member
I just removed my IM, replaced gaskets and PCV valve/hose. When i put it back together i ended up putting a different (newer) IAC on. It was siezed up, and prevented my car from starting unless i had gas pedal pressed(open throttle) I hit it with my socket wrench and it worked for a bit then stalled again at idle. I replaced it with my old IAC and car runs back to normal.
As for stalling at lights etc. My car did the same thing, ran great while in open throttle but whenever i let off the gas pedal i stalled quickly.
I again fixed this by replacing the IAC with my older working one.
Not saying this is what your issue is, but noting its similar with what i just did to my car.
One more thing to make sure is that your Intake is sealed from the MAF to the throttle body, any leaks that bypass the MAF and cause bad reads could also be culprit to stumbling/poor idle. I know my car did not like not having the Intake attached to the throttlebody when i was trying to use Seafoam IM/TB cleaner by spraying it at the TB plate. I had to use the plastic tube it comes with cut to fit the rubber boot and seal it back over the throttle body.
Fangren is offline
Old 02-14-2014, 07:55 AM   #40
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
its starts~!!!!!!
Cool Cool Guys!! as usual the body informs the head! thats why
I ordered parts from ebay. 30 bux for both shipped. Today is the day. Im headed to my buddies to drop the rad and pull the IM. Im wondering.......
Should I do tumble flaps delete?
Should I delete EGR while I have the heart in my hands?
Feedback accepted!!!
