Are prothane swaybar bushing suppose to be noisy? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-10-2013, 07:28 PM   #1
Drk_pssngr
Fan#: 119391
What I Drive: Blue
Points 290, Level 5
Points: 290, Level: 5 Points: 290, Level: 5 Points: 290, Level: 5
Level Up 80% Completed
FF Reputation: 1 Drk_pssngr Good Standing Member
I recently installed svt front and rear sway arms with new prothane bushings on my mk1 zx3.
They squeak all the time at every single bump and imperfection on the road.
I did use the super grease it came with it but it sounds like an old worn out spring mattress!!!
Are they breaking in? This can be normal at all!
Drk_pssngr is offline
Old 12-10-2013, 07:55 PM   #2
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
Points 2,118, Level 27
Points: 2,118, Level: 27 Points: 2,118, Level: 27 Points: 2,118, Level: 27
Level Up 79% Completed
Forum Activity 15%
Buy-Sell-Trade Rating: (13)
I've had mine in for three years and I haven't had a squeak yet.
I just remembered that you have to use clamping collars (or a piece of heater hose with hose clamps) on both ends of the swaybar. The reason is the swaybar will "walk" on the bushings because they don't "lock" into the swaybar indentations like the stock ones.
Sniper Focus is offline
Old 12-10-2013, 08:00 PM   #3
Drk_pssngr
Fan#: 119391
What I Drive: Blue
Points 290, Level 5
Is that for front and rear?
Old 12-10-2013, 08:23 PM   #4
Sniper Focus
Fan#: 84221
Forum Activity 15%
Yes..
Old 12-10-2013, 09:58 PM   #5
Drk_pssngr
Fan#: 119391
What I Drive: Blue
Points 290, Level 5
I'm just gonna replace them to stock replacement bushings. I can't stand the noise anymore. The fronts where sucha a bitch to do I cursed myself I would never do it again but here we go...working in 32 degree weather ftw!
Old 12-11-2013, 08:30 AM   #6
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,870, Level 59
Points: 7,870, Level: 59 Points: 7,870, Level: 59 Points: 7,870, Level: 59
Level Up 60% Completed
Forum Activity 27%
Buy-Sell-Trade Rating: (15)
http://www.polybushings.com/pages/bushinglube.html
http://www.alloutracing.com/store/sp...-tube-902.html
http://www.energysuspensionparts.com...shing-Lube.asp
Did you lube everything up good with the supplied grease? Pretty sure any silicone based grease will do. I wish all suspension fittings came with zirks...
rambleon84 is offline
Old 12-11-2013, 09:40 AM   #7
Drk_pssngr
Fan#: 119391
What I Drive: Blue
Points 290, Level 5
Yes I did use their supplied lube creeks and sqeeks all over the place still.
Old 12-11-2013, 08:09 PM   #8
ShadowFocus603
ShadowFocus603's Avatar
Fan#: 118448
What I Drive: 2004 Pitch Black SVT EAP 2Dr #1878
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
FF Reputation: 1 ShadowFocus603 Good Standing Member
did you over tighten the sway bar mounts that go around the bushings? ive read that over tightening them (to the point where there is no visible split in the bushing) can cause noise and binding. from what I understand there should be ~1mm gap or so in the bushing. if you have the bushing on the bar, hold it firmly around bar and whatever gap you see there should be what you see on the car when the mounts are tight. some people use fender trim washers to get the fit perfect while still being able to tighten the bolts fully.
ShadowFocus603 is offline
Old 12-11-2013, 11:56 PM   #9
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,690, Level 76
Points: 13,690, Level: 76 Points: 13,690, Level: 76 Points: 13,690, Level: 76
Level Up 10% Completed
Forum Activity 100%
Thats what I'd say^^^^^^^^ Some of the front bars did walk back & forth slightley= hence the squeaks. Try joncing or pushing down on the front end & listen for your squeaks.
felixthecat is offline
