strut replacement--one or both? - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-01-2013, 03:59 PM   #41
fearfeasog
Fan#: 122137
What I Drive: Silver (grey) 2004 Focus ZTW
FF Reputation: 1 fearfeasog Good Standing Member
Thankyouall!!!!
Ok, I just finished the strut replacement.
It really wasn't hard, save for some reason getting the damaged strut out of the steering knuckle. The other one came right out. The strut didn't even look damaged...just old. Maybe the learning curve. 3 hour job. First strut took 2.
Anyway, just wanted to thank you all profusely for your help and advice, I really appreciate it!
ff
fearfeasog is offline
Old 12-01-2013, 08:30 PM   #42
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,431, Level 21
Level Up 31% Completed
FF Reputation: 2 Miztaken1312 Good Standing Member
A block of wood, a rubber mallet, and some rust penetrater worked wonders on mine when removing it from the knuckle.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 12-02-2013, 10:34 AM   #43
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Points 3,995, Level 40
Level Up 23% Completed
You got it all done, I'm assuming the problem has been cleared up?
2011 SES 5spd #006 >> SR #213
mac.mogul is offline
Old 12-04-2013, 09:07 AM   #44
fearfeasog
Fan#: 122137
oh yeah, forgot to mention that! yes! all better!
Old 01-13-2014, 03:57 PM   #45
fearfeasog
Fan#: 122137
Well, here's a thing--now some weeks after the repair, the right side is fine, now it's the left side making a noise, kinda similar to the old noise from the right side. jeebus. it happens when the steering is turned all the way to the left, going slow or just starting up, also stationary to some degree. I opened the hood to have a look at the top of the strut mount while turning the wheel but didn't see anything odd. the sound from that point of view almost sounds like it's coming from the steering column, but I wouldn't know anything about that. going to go do a proper FF search now...
Old 01-13-2014, 05:59 PM   #46
Elder
Points 13,391, Level 75
Points: 13,391, Level: 75 Points: 13,391, Level: 75 Points: 13,391, Level: 75
Level Up 36% Completed
On mine one of the NEW sway bar end links loosened up a while after their installation, that's one thing to check since they were off to install the new struts.
I know you put on assembled struts, but checking the shock bolt in the center to make sure it's tight is another quick check.
Searching for noises again - PITA
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 01-13-2014, 06:09 PM   #47
fearfeasog
Fan#: 122137
Luck!
Thanks for the leads, I'll do both those things! serious pita, esp since it's dark out ALL THE TIME here. ok not really, but i have abt 3o minutes of daylight on the weekdays outside of work. guess I'll try lunch break.
ff
Old 01-13-2014, 07:16 PM   #48
Miztaken1312
Fan#: 74993
I still hear the occasional pop from the front springs going down the driveway at angle (has to be a sharp angle to avoid scraping now). I attribute this to not putting the rubber ends on the springs. No noise otherwise.
