How thick of an adapter do I need for new wheels? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-08-2013, 03:30 AM   #1
z4nder
z4nder's Avatar
Fan#: 103345
What I Drive: 2010 Sangria Red SES
Points 866, Level 15
Points: 866, Level: 15 Points: 866, Level: 15 Points: 866, Level: 15
Level Up 66% Completed
FF Reputation: 1 z4nder Good Standing Member
I finally found a set of wheels that has everything I'm looking for. I drive a 2010 focus sedan ses, and currently have the stock 17" wheels. I'm looking at getting the Tenzo Meister Matte Black V.1. If getting these I definitely want to go 18" which will be 18x8 with 42 offset. The question is they are only in 4x100 bolt pattern. I'm not too familiar with wheel adapters, but was wondering what size as in thickness do I need?
thanks, Alex!
Sedan Revolution #287
Tennessee Focus Owner #12
z4nder is offline
Old 06-08-2013, 03:31 AM   #2
z4nder
z4nder's Avatar
Fan#: 103345
Also, I'm running Eibach Sportline springs.
z4nder is offline
Old 06-08-2013, 04:55 AM   #3
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
I believe the minimum thickness they make is 1". You'd have to do the math to figure it out. 1" = 25.4 mm.
TerryB is offline
Old 06-08-2013, 09:02 AM   #4
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
With adapters it's going to push the wheel to far out of the fender and you rub a lot, plus the fact there not safe at all
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 06-08-2013, 10:05 AM   #5
Giraffe
Giraffe's Avatar
Fan#: 115278
What I Drive: 1999 Kombi (German-spec wagon)
FF Reputation: 1 Giraffe Good Standing Member
Compare the offset and/or backspacing of your stock wheels with that of what you want to purchase. That'll give you an idea of how thick of a spacer you can go with before your tires are outside of the fender.
You also need to be mindful of the inner hub bore diameter on the new wheels. If it's anything different than stock, you'll need either hub-centric rings (if the diameter is larger than stock) or a hub-centric/wheel-centric adapter with the correct hub size for your new wheels. That can get into custom adapter territory which can be spendy.
The key to all this is knowing your stock wheel's offset and backspacing specs and comparing that with the wheels you want to purchase.
1999 Ford Focus Kombi (Ist German for wagon, ja?)
Giraffe is offline
Old 06-08-2013, 02:25 PM   #6
jetrinka
jetrinka's Avatar
Fan#: 45622
Won't work. Offset too low already and with an adapter its gonna push that wheel out way too far.
jetrinka is offline
Old 06-08-2013, 03:10 PM   #7
z4nder
z4nder's Avatar
Fan#: 103345
Hmm, that sucks, I thought I finally found what I was looking for haha. Does anyone know of a site that has something like that style in 18" and in 4x108? I feel like I have searched everywhere and only have found them in either 17" or in a different bolt pattern.
Here's what I'm looking for.
http://www.wheelstudio.com/view-whee...ll/vehicle-all
z4nder is offline
Old 11-19-2013, 10:27 PM   #8
aaron1986
Fan#: 120088
What I Drive: 2001 Sangria Red ZX3 S2 edition
FF Reputation: 1 aaron1986 Good Standing Member
Does anybody know wat wheel adapters size i need to switch out my stock 4 lug 4 x 108 mm 4.25 inch to 4 lug 4 x 108 mm 4.50 inch? I have stock 16 inch rims on now but trying to get my 17 inch 4 lug 4.50 on. I drive a 2001 Ford Focus ZX3 with drum brakes in the rear. Please.........
aaron1986 is offline
Old 12-09-2013, 01:51 AM   #9
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
Lots of poor information in this thread, even if most of it is 1/2 a year old it's worth correcting.
First 18x8 ET42 isn't already too low of an offset, it's the same specs as MK1 RS wheels which fit any 1999-2011 NA focus easily.
Next, I'm not sure what info Indy is working with but wheel adapters are plenty safe as long as (just like anything) you don't cheap out and you use quality components.
Finally, I'm not even really sure what Aaron is referring to. Could you clarify what you mean by 4.50 inch? Are you talking about the backspace or do you mean that the bolt circle is 4x4.5 instead of 4x4.25?
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 12-11-2013, 01:50 AM   #10
BlueFocusSE5
Fan#: 97166
What I Drive: 2002 Ford Focus
FF Reputation: 1 BlueFocusSE5 Good Standing Member
Wheel spaces can be very dangerous as they greatly increase the load on the wheel studs, which can cause them to break, with the result being a wheel flying off the car.
At the auto centers I've run, we were not allowed to install wheel spacers under any circumstances because of the great danger is meant for our customers and the legal liability it exposed the company to.
-- B.F. Goodrich T/A Certified Tire Specialist
BlueFocusSE5 is offline
