Denso or Weapon X Ignition coils?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-07-2013, 08:42 PM   #1
lyonidas13
Fan#: 109972
What I Drive: 2003 D23 SE
FF Reputation: 1 lyonidas13 Good Standing Member
So im looking at purchasing new Coils for my Duratec 23. The two choices ive decided on are OEM Denso coils or upgrade to Weapon X level 2 efx coils. I read somewhere on the forum that the weapon x coils don't really do much but there only about 40 bucks more than the Denso's(on Rockauto.com)
I was just looking for some input or suggestions before I made the decision. Im mainly concerned with performance and longevity of the coil. Also if anyone recommends any other type or coil please let me know!
thanks
lyonidas13 is offline
Old 11-07-2013, 09:03 PM   #2
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
Points 28,322, Level 98
Points: 28,322, Level: 98 Points: 28,322, Level: 98 Points: 28,322, Level: 98
Level Up 98% Completed
Buy-Sell-Trade Rating: (29)
Stock coils are good for any power level youll ever reach. Weapon X are pretty but thats it
Do you need new ones? Usually its just the boots that go, if anything
==2012 Kona Blue Mustang V6==
==1972 Skylark==
Buickboy is offline
Old 11-07-2013, 10:52 PM   #3
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,788, Level 76
Points: 13,788, Level: 76 Points: 13,788, Level: 76 Points: 13,788, Level: 76
Level Up 35% Completed
Forum Activity 100%
I'd install a set of Denso IT20's. What makes you say you have coil problems?
felixthecat is offline
Old 11-09-2013, 11:50 AM   #4
RPMisChris
RPMisChris's Avatar
Fan#: 76276
What I Drive: 07 svt 2.3 swap thing
Points 5,336, Level 46
Points: 5,336, Level: 46 Points: 5,336, Level: 46 Points: 5,336, Level: 46
Level Up 93% Completed
FF Reputation: 1 RPMisChris Good Standing Member
Buy-Sell-Trade Rating: (16)
there are some weapon x's for cheap on the forum. Check it out.
RPMisChris is offline
Old 11-09-2013, 07:13 PM   #5
lyonidas13
Fan#: 109972
Im really just looking to start replacing things on the car. Its getting pretty high in mileage (almost 192,000). I just switch to ar103's the other day and I have a fswerks intake. Ive also replaced the intake manifold gasket and motor mounts.
It is throwing two codes. One for the IMRC on the IM and the other is the p0420 code for the cat. My only complaints with it are occasional hard starting maybe once to twice a week. Ill go to start it and it will turn over but wont start so ill turn the key to off and it will start right up. It used to do this when I first got it so I cleaned the MAF, IAC valve and throttle body and it didn't do it for probably 40,000 miles. Ill clean it out some weekend when I get a little time and see what happens.
My second complaint only happens when the car is on and idling. It will make like a whirr, whirr, whirr noise like its dropping rpms for a split second. Its kinda hard to explain without actually hearing it. It doesn't happen all the time, its pretty random. I usually notice it at a stop light or something like that.
Old 11-09-2013, 07:42 PM   #6
lyonidas13
Fan#: 109972
I forgot to mention before but when I changed out my spark plugs a couple days ago I noticed there was a dark reddish color built up on the electrode. The old spark plugs were APP 104's. It smelt like gas so im assuming its running rich but I don't know for sure. Any input on this would be great! Im wondering if this is related to my hard starting issue or p0420 code.
Old 11-09-2013, 07:47 PM   #7
RPMisChris
RPMisChris's Avatar
Fan#: 76276
I have had start up issues since I bought my car new. It is common in the foci. You will turn it over for a few cranks and it wont start. Then you turn the key to off and it will start right up. Dont worry about it.
Check your alternator! Even if it tests out as being fine it is usually the alternator anyways. Just replace it as it is a relatively simple and easy thing to do.
