Installing Cruise Control on 08-11 - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-25-2013, 10:33 PM   #31
gnx405
Fan#: 111026
What I Drive: 2008 Focus SE
Points 6, Level 1
Points: 6, Level: 1 Points: 6, Level: 1 Points: 6, Level: 1
Level Up 11% Completed
FF Reputation: 1 gnx405 Good Standing Member
Originally Posted by md2009 View Post
It is my understanding that there is a difference between the radio installed with the buttons on the steering wheel and the radio installed without those buttons.
I have no first hand experience, but I seem to remember a thread where someone tried the same thing and they were not able to get the radio or sync buttons to work.
If you decide to give it a try please let us know if it works! I commute 124 miles each day, and the cruise control has worked flawlessly for the past year after the install!
Update on my wheel swap.
I ended up installing a wheel that has both cruise and sync buttons on my car which was originally equipped with a steering wheel without any buttons.
Took it to the local dealership and they enabled speed control and charged ~ $85 to do so.
The cruise functions normally, but the sync buttons do not control anything. Like others have stated, the radio needs to be swapped in order for the radio buttons to function.
gnx405 is offline
Old 05-30-2013, 11:10 PM   #32
thespiderman
Fan#: 115253
What I Drive: 2009 Red Ford Focus
FF Reputation: 1 thespiderman Good Standing Member
Here's a little twist
I just picked up my first Focus. A 2009 with cruise control. The steering wheel is really in rough shape. Looks badly aged and decomposing. I found some brand new OEM steering wheels for just $50, but they don't have the cruise option. I was wondering if I could buy one and then do some precision cutting of the left side so that I could put in the cruise controls from my original wheel. Anyone have enough experience comparing the two wheels to know if this is possible? I would really like to have a brand new wheel but I don't want to spend the $332 my dealer quoted me. If I have to, I'll get a wheel wrap, but that is also my second choice to having a brand new OEM wheel for just $50.
thespiderman is offline
Old 06-04-2013, 10:52 AM   #33
nickstewartroc
Fan#: 93665
What I Drive: 2011 Blue Focus SE
Points 301, Level 6
Points: 301, Level: 6 Points: 301, Level: 6 Points: 301, Level: 6
Level Up 2% Completed
FF Reputation: 1 nickstewartroc Good Standing Member
I plan to do this with mine that didn't come with Cruise, it looks like you should be able to!
nickstewartroc is offline
Old 08-05-2013, 04:13 PM   #34
MN_Moose
Fan#: 114958
What I Drive: 2009 Silver Focus SE coupe
FF Reputation: 1 MN_Moose Good Standing Member
Originally Posted by myke View Post
saw this on another forum seems you can enable cruise control yourself (and other features too) not tried it myself but feedback from other members seems good you need an elm cable and to download some freeware
http://www.fordownersclub.com/forums...d-ff2-program/
hope its ok to link to other forums if not please delete
DO NOT TRY TO DO THIS ^ PROGRAMMING ON YOUR OWN - for American cars, this will not work, and you will spend your time and $ for naught.
Secondly, I do not recommend renting a steering wheel removal kit from an autoparts store - the Gen II focus steering wheel was designed to be removed with a small 2-jaw puller (which can also be rented from an autoparts store):
I hope these corrections save others the time and agony I recently went through.
MN_Moose is offline
Old 10-14-2013, 02:33 PM   #35
cm1seabee
Fan#: 119813
What I Drive: 09 Focus
FF Reputation: 1 cm1seabee Good Standing Member
Upgrade Complete
I completed this upgrade in like 20 minutes, It was hard to find the right puller, had to modifiy the one I got from O'Reilly's, other than that it was a snap, This thread was great, thanks for the great pictures. I was able to have the cruise turned on for like 30 dollars at Parks Ford in Tampa, no hassle no fuss.
cm1seabee is offline
Old 10-26-2013, 03:38 PM   #36
wheelinfool73
Fan#: 120191
What I Drive: 2008 blue Focus
FF Reputation: 1 wheelinfool73 Good Standing Member
Extremely helpful thread! Cruise installed and works perfectly!
wheelinfool73 is offline
Old 01-29-2014, 05:32 PM   #37
dbcooper
Fan#: 138609
What I Drive: 2008 Green SE
FF Reputation: 1 dbcooper Good Standing Member
Ya, I've been reading about that and wondered. Did you actually try it?
dbcooper is offline
Old 11-27-2014, 10:22 AM   #38
glentz
Fan#: 204858
Points 1, Level 1
Points: 1, Level: 1 Points: 1, Level: 1 Points: 1, Level: 1
FF Reputation: 1 glentz Good Standing Member
elm config, ff2 etc for american ford
I tried it. Programs can read module info but I couldn't enable cruise. I used elm-ff2 program on 2010 focus se after swapping steering wheel. checked the cruise option in BCM and hit write. Says successful but no matter what I did the option was not actually enabled. re-reading module info always showed cruise not active.
glentz is offline
Old 11-28-2014, 12:40 AM   #39
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
FF Reputation: 2 Miztaken1312 Good Standing Member
That's because that's the EUROPEAN Mk2. That site is for all Euro cars.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 11-28-2014, 06:46 PM   #40
badazz2010focus
Fan#: 78166
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
Derp lol jk
badazz2010focus is offline
