Door Handle Broken Inside - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-19-2013, 10:30 AM   #11
Phestezio
Phestezio's Avatar
Fan#: 97562
What I Drive: 2007 Oxford White ZX3
Points 1,268, Level 19
Points: 1,268, Level: 19 Points: 1,268, Level: 19 Points: 1,268, Level: 19
Level Up 68% Completed
Forum Activity 7%
FF Reputation: 4 Phestezio Good Standing Member
Yeah I was thinking it was a piece connecting to the outer door handle. And I probably shouldn't have said "rip" haha. I was thinking it should be pretty self explanatory once you see it that you can pull the interior water shield off by grabbing the edges and carefully pulling it away from the gooey black adhesive so you can put it back on when your done. My bad.
Phestezio is offline
Old 10-19-2013, 10:51 AM   #12
Gudziel
Gudziel's Avatar
Fan#: 72249
What I Drive: 2007 Aqua Blue ZX4 SE
Points 3,126, Level 34
Points: 3,126, Level: 34 Points: 3,126, Level: 34 Points: 3,126, Level: 34
Level Up 51% Completed
FF Reputation: 2 Gudziel Good Standing Member
Buy-Sell-Trade Rating: (7)
Originally Posted by amc49 View Post
DON'T rip the inner door water shield off, cut the adhesive carefully with a razor blade while you slowly pull the edges up, then you can simply restick it back down when the job is done. The adhesive never dries.
The outside door handle breaks easier when the latch at back of door tightens up from no lube, the extra effort needed to open door then breaks the outer handle actuating tab.
Thank you for the suggestion. I was wondering about that adhesive if I would need to replace it or not after install. No one ever said different. Thank you!
My reinforcement bracket did not come with any piece inside if the plastic part that moves up and down on the spring. I thought it looked odd when opened it after I purchased it but couldn't think of why. In the video I linked earlier there is a yellow piece in that arm. Mine does not have anything in there.....
Sent from my DROID RAZR using FF Mobile
SR# 307
My Build/Mod Thread: http://www.focusfanatics.com/forum/showthread.php?t=462393
Gudziel is online now
Old 10-20-2013, 01:33 PM   #13
Gudziel
Gudziel's Avatar
Fan#: 72249
Smile
I just fixed the reinforcement bracket. It was not bad at all. It took about an hour and half to fully finish the job.
The original piece was a crappy plastic arm that broke. The new piece for my '07 was all metal which is nice. I am thinking of just replacing the passenger side with a new one as well. It is starting to feel a bit "tense" when we open that door.
I appreciate all of the help from this forum. I'm very thankful not only for the advice, but for a fully operational door again!!!
Thank you!
