06-11 dampers on 00-05? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 09-29-2013, 11:20 PM   #1
Pur Pony
Fan#: 35217
What I Drive: 98 Explorer/89 TT Mustang/02 Focus
FF Reputation: 1 Pur Pony Good Standing Member
I know to fit 00-05 dampers and springs on a 06+ you need the massive omni kit..... (the omni kit if for what??? springs or dampers or both??)
but is there anyway to put 06-11 dampers and springs on a 00-05???
will 00-05 springs fit 06+ dampers?
thanks
'89 Mustang Coupe - Twin Turbo - 610rwhp 650rwtq
'98 Lincoln Mark VIII LSC - T-bird suspension / Mustang wheels
'98 Explorer Limited V8 AWD - DD
'02 Focus Sedan - FRPP springs/ KYB Adjustable shocks/struts
'99 Buell X1 - Fully Custom
Pur Pony is offline
Old 09-30-2013, 01:56 PM   #2
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 54 felixthecat Excellent Standing Member
For the struts.
Yeah, change out the spindles. But why, the earlier setup gives you alot more choices.
No.
thanks
What are you trying to do?
felixthecat is online now
Old 10-01-2013, 10:28 AM   #3
Pur Pony
Fan#: 35217
Felix- i know we were talking on PM but let me put this out there for others as well.
I just bought an 02 focus and im looking to set it up for handling but at the lowest cost possible.
I was going to go with FRPP lowering springs and KYB AGX dampers.... which would run me around $440. I was also planning on doing new moog lower control arms with ball joints and bushing... and the price is the same for 00-04 or 05... so if i bought 05 arms I get the larger ball joints. Then i could buy used spindles/knuckles/calipers for an 06 local for $100.... this would allow me to run the larger 05+ brakes (which im buying new rotors and pads anyways for 00-04 so..) and also allow me to run the larger diameter dampers. With the FRPP deal going on right now for the same price as the FRPP/KYB combo for an 00-04, I can get the FRPP springs/FRPP Tokico dampers/ 06 spindles/knuckles/calipers...
advantage - larger ball joints, larger brakes, larger dampers.....
anything im missing?
or I go with the Eibach "kit" for a 00-05?-
what to do...
Pur Pony is offline
Old 10-01-2013, 11:19 AM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
The simple answer is no as they made changes to the dampers and springs in the front.
You can fit 00-05 springs and struts to 06-11 cars with an adapter sold by one of vendors, Massive speed systems.
I always moderate naked!
bringler26 is offline
Old 10-01-2013, 09:25 PM   #5
felixthecat
Fan#: 80663
what to do...
The frpp's Dynamic damper kits, M-18000-ZXM & ZXM1 are the same price. So what your doing it all boils down to the springs= if you ever want to change them out, if you went the '06+ way, your stuck w/ those vs getting the dynamic dampers for the earlier cars & use '05 only spindles. To me its a no brainer to use the '05 only spindles w/ what ever spring/damper combo & of course you'd need to get bigger tapered ball joints or '05+ arms & those '05 spindles will take any BBK you want to use. The '05 only spindle allows you to use the popular '00-'05 spring/damper combo, bigger ball joints & the svt brake kit or any BBK.
