Voltage Surge 2000 Ford Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-28-2013, 12:44 PM   #1
sucof22
Fan#: 119316
What I Drive: 2000 Ford Focus
FF Reputation: 1 sucof22 Good Standing Member
We have recently been experiencing the Brake, ABS and Battery lights randomly flashing on the instrument panel. Also the lights will get notably brighter. I tested the voltage at the battery and noted surges near 18v. I don't have anything sophisticated...just a dial voltage meter. I figured the voltage regulator was bad and purchased a used alternator. I still have the same symptoms. I have a hard time believing that both alternators have a bad regulator. Not sure what else it could be.
sucof22 is offline
Old 09-28-2013, 11:08 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,146, Level 74
Points: 13,146, Level: 74 Points: 13,146, Level: 74 Points: 13,146, Level: 74
Level Up 74% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat".
zetecDon is offline
Old 09-29-2013, 02:48 AM   #3
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Question your volt meter used there..............
amc49 is offline
Old 09-29-2013, 10:13 AM   #4
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 955, Level 16
Points: 955, Level: 16 Points: 955, Level: 16 Points: 955, Level: 16
Level Up 55% Completed
FF Reputation: 3 CotyM Good Standing Member
Defenently, test the multimeter with a few stable known sources (Like a new 9v or a few new AA's... Also check it's batteries. My digital mulitimeter will give me absurd readings when the batteries are low.
Also if it defalts to automatic (detects AC and DC voltage automatically) be sure that it is set manually for more accurate readings...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
Old 09-29-2013, 11:21 AM   #5
mikeeshaq
Fan#: 72526
Points 626, Level 12
Level Up 52% Completed
I bet the multimeter is OK...
sucof22 this is what I want you to do:
Go right on the battery posts NOT the battery clamps measure the voltage
NOW go on the battery clamps and measure the voltage there
Your battery clamps have to be perfect! no corrosion and TIGHT!
Twist sideways the clamps must NOT move
Is there any wire insulation that is melted by the clamps? If so, then it must be corrected.
Report back
mikeeshaq is offline
Old 10-01-2013, 02:31 AM   #6
xFOCIx
Fan#: 23553
What I Drive: 2005 ZX3 5spd
FF Reputation: 15 xFOCIx Great Standing Member
When everything is right, the voltage difference between alternator and corresponding battery terminals should be 0.0x volts. (measure B+ at alternator to + on battery, alternator case to negative on battery)
Any deviation from this means you have a resistance due to poor connection which is usually from loose connection, corrosion at connection or terminal crimping.
Re-make all connections. Sand down and WD-40 before assembly if it looks corroded/rusted. If the corrosion is inside the crimping that attaches to wire, you may have to replace that cable if there's not enough length to cut off the terminal and put a new one.
xFOCIx is offline
