What to clean engine bay with? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-17-2013, 08:30 AM   #11
biking4life
Fan#: 102734
What I Drive: 2012 Honda Civic EX 5MT
Points 51, Level 1
Points: 51, Level: 1 Points: 51, Level: 1 Points: 51, Level: 1
Level Up 2% Completed
FF Reputation: 1 biking4life Good Standing Member
Has anybody had any electrical problems after hosing down the engine? I'm selling a car and don't want to damage anything before the sale but the engine is mighty dirty after 9 years!
biking4life is offline
Old 07-17-2013, 09:08 AM   #12
cdbertrand
cdbertrand's Avatar
Fan#: 97547
What I Drive: 00' Infra Red ZX3, gf's 08' SE
Points 3,096, Level 34
Points: 3,096, Level: 34 Points: 3,096, Level: 34 Points: 3,096, Level: 34
Level Up 31% Completed
FF Reputation: 2 cdbertrand Good Standing Member
Just make sure you use compressed air to get the water out from around the spark plugs. And if you rinse off the under side of your hood, make sure it's dry before you close your hood or water will get where it shouldn't be again.
Rally Revolution #17
When you turn your car on, does it return the favor?
When in doubt.. Flatout. - Collin McRae
cdbertrand is offline
Old 09-12-2013, 11:16 AM   #13
crice8
crice8's Avatar
Fan#: 84830
Points 8,540, Level 62
Level Up 30% Completed
Buy-Sell-Trade Rating: (13)
This is my engine bay that FSWerks uses as their picture to show the engine cover. I cover the electrical components with aluminum foil and spray the rest of the engine bay with a medium pressure flow. You can use a designated engine bay cleaner to break loose dirt and use brushes to agitate it. DO NOT USE SIMPLE GREEN!! It will cause aluminum to oxidize and corrode over time. After you rinse the engine bay very well to remove all soap or cleaners let it dry completely and totally. I then use Sonus Engine kote let it dry for 20 minutes then use another coat of it. This is a great product and actually repels dirt and dust and keeps the engine bay clean so washing it less often still maintains awesomeness(=
Hope this helps!
Here is a link to to Sonus Engine kote:
http://www.autogeek.net/sonus-trim-motor-kote.html
Galatians 6:14
crice8 is offline
Old 12-11-2013, 03:19 PM   #14
bmccrary
Fan#: 124993
What I Drive: 2014 SE Hatch
FF Reputation: 1 bmccrary Good Standing Member
I have been using the Black Magic Engine cleaner and shine. Red/black can. I used it on my Escape engine bay as well as my fender wells and various underbody stuff. Only thing I can say is that on the 2.5 there was a temp sensor that sat in between cylinder 2 and 3.. the rubber plug doesnt seal so water got in around that sensor and corroded it. Replaced it under warranty. After that I made sure to get all moisture out of the area after I washed it. (more care than I had in the past)
Here is my Escape engine bay after 50K miles. Several trips to the mountains in the snow, etc. Washed it every 10K miles with the cleaner. The stuff would foam up, I would let it sit for 10 minutes then hose off.
bmccrary is offline
Old 01-01-2014, 10:28 AM   #15
IngotMK3
IngotMK3's Avatar
Fan#: 42911
What I Drive: MK3 Focus
Points 4,121, Level 40
Points: 4,121, Level: 40 Points: 4,121, Level: 40 Points: 4,121, Level: 40
Level Up 86% Completed
FF Reputation: 1 IngotMK3 Good Standing Member
Purple power degreaser has worked well for me, give that a try!
IngotMK3 is offline
Old 02-25-2014, 06:56 PM   #16
ford_girl
ford_girl's Avatar
Fan#: 123641
What I Drive: '02 dark blue zx3 hatch back manual
Points 95, Level 1
Points: 95, Level: 1 Points: 95, Level: 1 Points: 95, Level: 1
Level Up 90% Completed
FF Reputation: 1 ford_girl Good Standing Member
I know this discussion is a little old but I am hoping I can get some help without starting a new discussion. I have a 2002 zecta manual and my power steering fluid leaked all over my alternator, belts, and engine. The guy at the shop said to have it steamed cleaned but to me that sounds like a bad idea. Any suggestions would be great, smelling power steering fluid getting burnt is not very pleasant and probably not good for my car.
~take it one day at a time~
ford_girl is offline
Old 02-25-2014, 07:46 PM   #17
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,258, Level 95
Points: 25,258, Level: 95 Points: 25,258, Level: 95 Points: 25,258, Level: 95
Level Up 91% Completed
I would just take it to the car wash and spray it out with the sprayer. Keep the engine running, but spray once with the tire cleaner, let it sit for a few seconds, then spray it with the soap and finally rinse. With the soap and rinse I wouldn't worry about using high pressure. If you're not trying to detail then that should do well enough.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 02-25-2014, 07:59 PM   #18
cdbertrand
cdbertrand's Avatar
Fan#: 97547
Wouldn't you have to cover the spark plugs and battery?
Old 02-25-2014, 08:50 PM   #19
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
I never have, and I wash my engine a lot. You don't want to use high-pressure water on them, but it's perfectly acceptable to allow them to get wet. Maybe it's just simpler for me because I keep my engine bay pretty clean, but all electrical connections have an environmental barrier built into them.
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 02-25-2014, 09:19 PM   #20
rexazz2
rexazz2's Avatar
Fan#: 121761
What I Drive: 2014 HB SE
Points 1,928, Level 26
Points: 1,928, Level: 26 Points: 1,928, Level: 26 Points: 1,928, Level: 26
Level Up 28% Completed
Forum Activity 12%
FF Reputation: 1 rexazz2 Good Standing Member
BTW keeping the battery clean is a good thing
A build up of crud can cause power drainage
rexazz2 is offline
