SVT PS line a direct fit on zetec PS pump ? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-11-2013, 01:06 AM   #1
homelessmonkey
homelessmonkey's Avatar
Fan#: 98498
What I Drive: 2003 black zx3
Points 847, Level 15
Points: 847, Level: 15 Points: 847, Level: 15 Points: 847, Level: 15
Level Up 47% Completed
FF Reputation: 2 homelessmonkey Good Standing Member
Hey everyone,
So my ps line is starting to leak, I am thinking of changing to an svt line since i swapped my header might also change the pump while I am at it.
I just wanted to know if anyone knows if a stock svt PS line will be a direct fit with the zetec one.
I know CFM sells a relocating kit but with shipping and duty's it would come down to 110.
My part store can get the svt line for 65.
rock auto gives some nice dimensions but I don't know what to make of it.
EDELMANN Part # 92104 11mm Male Captive O-Ring x 16mm Male Swivel O-Ring x 62 7/8" (w/Switch Port). LX Model; SE Model; ZTS Model; ZTW Model; ZX3 Model; ZX5 Model; w/Switch Port
EDELMANN Part # 92102 11mm Male Captive O-Ring x 16mm Male Swivel O-Ring x 91 5/8" (w/Switch Port)SVT Model
Any help is a appreciated thanks
homelessmonkey is online now
Old 08-11-2013, 01:14 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (11)
Yes it will fit with no problems, well small problems, such as the pressure switch is mounted on the pump on the non SVT pump and the switch/sensor is located on the power steering line itself. Just find a bolt to screw into the hole, that's what I did. Everything else was just easy remove and reinstall. Though it's a little tighter going around the trans due to the MTX-75 being either a little bigger than the Getrag or smaller I forget which but it's one of those. Be mindful by the shift linkage. I had my line move and block me from being able to put it in gear one time. I just needed to move the line to a better spot, I can't remember if I ziptied to something or not since it's been a while. I used the Gates brand power steering line for the SVT, but the Edelman should do just fine as well, I just like the Gates brand lol
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 08-11-2013, 10:07 AM   #3
homelessmonkey
Fan#: 98498
Awesome man, thanks for the quick reply !
So I just have to plug a hole which is located on the svt line or on the zetec pump ? anypics of what im looking for would be cool. :)
What about if i just went with a svt pump and line on a zetec would that work better ?
Old 08-11-2013, 08:07 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
That would work too. I wanna say they are the same pump just with a plug or a sensor but I couldn't be too sure on that.
Moderator for
Technical Chat
Old 08-26-2013, 05:38 PM   #5
maxwell_bud
maxwell_bud's Avatar
Fan#: 117818
What I Drive: 2003 Black ZX3
Points 423, Level 8
Points: 423, Level: 8 Points: 423, Level: 8 Points: 423, Level: 8
Level Up 46% Completed
FF Reputation: 1 maxwell_bud Good Standing Member
what did you end up doing? I'm curious because I want to swap over to the SVT headers as well
maxwell_bud is offline
Old 08-26-2013, 08:09 PM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
HERE is the link to the How To lots of great info in there that will probably answer your question.
Moderator for
Technical Chat
Old 08-29-2013, 11:52 PM   #7
homelessmonkey
Fan#: 98498
I ended up just getting the SVT ps line (Edelmann #92102) came with the connector already on. I am in the process of trying to get an svt pump from another member.
But the pump isnt needed. Just make sure to look if your sensor is on the line or on the pump mine was on the line so it just swapped.
Old 08-31-2013, 06:54 PM   #8
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,153, Level 74
Points: 13,153, Level: 74 Points: 13,153, Level: 74 Points: 13,153, Level: 74
Level Up 76% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (46)
That's almost like the SVT line that I got from Ford. If you had the Motorcraft version you would have had to buy the nut that connects to the power steering pump separately from the rest of the hose. About the only problem that aggravated me so much about the aftermarket lines was the connector plate that goes onto the steering rack. It just seems that they didn't fit right and that's the reason I went with the SVT line.
zetecDon is offline
Old 09-01-2013, 06:55 PM   #9
homelessmonkey
Fan#: 98498
I wouldve gone with the oem svt line but my ford dealerships said they cant get it anymore lol.
Old 11-23-2013, 05:15 PM   #10
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,597, Level 62
Points: 8,597, Level: 62 Points: 8,597, Level: 62 Points: 8,597, Level: 62
Level Up 49% Completed
Forum Activity 25%
I called up my dealer because I needed a new line and they said the same thing.
Any one know the bolt size to block off the port? I don't think I need a new pump and would rather not replace it till needed. Until then I need to plug this"extra" port up.
Thanks
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
