Opinions on header wrap for svt header? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-29-2013, 11:42 PM   #11
homelessmonkey
homelessmonkey's Avatar
Fan#: 98498
What I Drive: 2003 black zx3
Points 845, Level 15
Points: 845, Level: 15 Points: 845, Level: 15 Points: 845, Level: 15
Level Up 45% Completed
FF Reputation: 2 homelessmonkey Good Standing Member
I wrapped my svt header with a roll of 2inx50ft dei titanium had about 6ft left, keeps the engine temp down and you don't need to seal it.
What I did was wrap one tube then measure how much I used for that tube, then cut 4 strips that length with 1 inch more and then you have like 20 ft left for the bottom.
Just make sure you have your bung welded in before you wrap it(or have a delete for the egr) I made that mistake, I only realized after I was done and I had to re-wrap it and then the wrap was starting to fall apart so don't play with it too much.
http://www.focusfanatics.com/forum/showthread.php?t=316481
homelessmonkey is online now
Old 08-30-2013, 12:03 AM   #12
02rsv02zx3
02rsv02zx3's Avatar
Fan#: 114073
What I Drive: 2002 Liquid grey ZX3
Points 1,364, Level 20
Points: 1,364, Level: 20 Points: 1,364, Level: 20 Points: 1,364, Level: 20
Level Up 64% Completed
FF Reputation: 1 02rsv02zx3 Good Standing Member
Ok thanks... Happen to remember the lengths that u cut for each tube? Also have u had any issue with the wrap and oil?
02rsv02zx3 is offline
Old 06-01-2014, 01:16 PM   #13
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
What I Drive: chcl gry 02 ZX3 - 5sp
Points 6,151, Level 51
Points: 6,151, Level: 51 Points: 6,151, Level: 51 Points: 6,151, Level: 51
Level Up 1% Completed
Forum Activity 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
Buy-Sell-Trade Rating: (18)
USE GLOVES!!!!!!
I used 3 x 25' lengths of Red SickSpeed 2" wrap, from eBay. I used all but about 4 feet of it. Came with stainless pull ties, I used 12 out of 15? Coated with VHT ceramic clear when done.
You need to wrap 2 pipes down to the first collection point and then wrap the other two down to the bottom collection point.
Overlapped 1" - I didn't wrap all the way down because my car is way low and the header will probably scrape so no need to wrap what will be scraping eventually.
You should soak the wrap in water before wrapping, makes it more pliable.
"You are a person, No one can forget you, even if it's Good or Bad, you make waves!" #truth #truthinadvertizing...
R.I.P. Pat :-( HN #68 - FTO #008 - principal defensor para el diablo
daspazzZX3 is online now
Old 06-02-2014, 07:45 PM   #14
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,580, Level 62
Points: 8,580, Level: 62 Points: 8,580, Level: 62 Points: 8,580, Level: 62
Level Up 44% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
used a 50 foot and a 10 foot section. and had a little bit left over. but wanted to make sure that i had enough to get it all done and it will frey when doing bits. so trimmed a bit a few times to get a good edge.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 06-03-2014, 12:34 AM   #15
TexasFoCi
Fan#: 118867
What I Drive: 2001 ZX3 5 Speed with 255,000 Miles
Points 1,570, Level 22
Points: 1,570, Level: 22 Points: 1,570, Level: 22 Points: 1,570, Level: 22
Level Up 70% Completed
FF Reputation: 2 TexasFoCi Good Standing Member
titanium DEI wrap 50' roll. wrap it tight but not too tight., take your time. soak it in water before you wrap it.
aircraft saftey wire or a thin copper wire to hold the ends in place.
TexasFoCi is offline
