how to hook up waste gate, BOV, boost gauge and a boost controller??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-07-2013, 09:41 AM   #1
kwg2371
kwg2371's Avatar
Fan#: 82857
What I Drive: 03 screming yellow SVT #1841
Points 3,827, Level 39
Points: 3,827, Level: 39 Points: 3,827, Level: 39 Points: 3,827, Level: 39
Level Up 18% Completed
FF Reputation: 3 kwg2371 Good Standing Member
hopefully this easier than it looks. This is my first turbo install and I have no idea on how to run the vac lines
the xios kit I got came used and the last owner switched it to a blow through set up and added the BOV and boost controller
so to start here are some pics
the one with the brass nut for the boost guage needs to be tapped into the intake manifold right??? if so where does it go or whats the easiest spot to tap into
the one on the top right should go to my waste gate and the cold side housing of the turbo per the instructions I have got for hooking up the turbo kit but does anything else get connected to it? seen in this pic
as for the boost controller and the last hoses I have no idea how to hook them up
the only other place I have to run a line is too the BOV does it go there and another into the IM?
i assume it goes there?
and last but not least after going over my boost controller I noticed it has a tiny hole in it, is it supposed to be there?
thanks for any help or advice you can give me
HatchNation #36
FF 13 best audio
FF 13 3rd place best in class SVT
FFW 13 best focus
FFW 13-14 best in class SVT
kwg2371 is offline
Old 07-07-2013, 11:55 AM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Buy-Sell-Trade Rating: (11)
is that a manual boost controller? if so im not to familiar with them. but the way I ran mine was the com port needs a vacuum source like a line teed off the intake manifold. the bov vac goes to the manifold as well. and wastegate ports depends on how you run your sytem. either with boost controller or just spring pressure. spring pressure u leave the top port vented to atmosphere and bottom goes to the intake. if using the boost controller have the top port go to the NO side of the controller
FF MODERATOR
RIFF CREW
ZXthrizzle05 is offline
Old 07-07-2013, 06:06 PM   #3
kwg2371
kwg2371's Avatar
Fan#: 82857
the wastegate is built in
HatchNation #36
FF 13 best audio
FFW 13 best focus
kwg2371 is offline
Old 07-07-2013, 07:07 PM   #4
ZXthrizzle05
TURBO ZX3
Fan#: 24434
I see u have an internal gate. Then u would usethehose teed off from the gate port to the mbc
FF MODERATOR
RIFF CREW
Old 07-07-2013, 08:19 PM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
I wouldnt use the fitting on the turbo , I would plug that one and get boost reference from the intake manifold
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 07-08-2013, 01:33 AM   #6
kwg2371
kwg2371's Avatar
Fan#: 82857
is there an IDEAL line to tap into on the IM? the brass fitting screws onto my boost gauge inside of the car
so a far as other lines hook one to the cold side of the turbo then run that to the MBC tee off of that line that gets hooked to the waste gate? and run the other from the BOV?
HatchNation #36
FF 13 best audio
FFW 13 best focus
kwg2371 is offline
Old 07-08-2013, 10:10 AM   #7
egbertnr
Focus Factor
egbertnr's Avatar
Fan#: 27383
What I Drive: 2011 Blue FX4 F150 SCREW Boosted
Points 10,821, Level 68
Points: 10,821, Level: 68 Points: 10,821, Level: 68 Points: 10,821, Level: 68
Level Up 93% Completed
FF Reputation: 7 egbertnr Good Standing Member
Buy-Sell-Trade Rating: (19)
Check this page.. http://www.tmaturbo.com/installation.htm
Pull all boost/vac references from your IM. IF you have to run a T fitting from the IM. I actually used a Jay Racing manifold. That way you only have one tap into your IM and you can use this for all teh boost references you need. http://www.jayracing.com/vacuum-mani...ck-p-4023.html
2011 F150 FX4 Blue Flame Metallic SuperCREW EcoBoost 371RWHP/458RWTQ
1986 Mustang Coyote Swap in progress
2013 Focus ST3 Performance Blue-Gone
89 Mustang 5.0 Turbo 670 rwhp-Gone
03 SVT Focus Turbo 326whp/278wtq-Gone
egbertnr is offline
Old 07-09-2013, 08:46 PM   #8
kwg2371
kwg2371's Avatar
Fan#: 82857
so then I did it wrong then?
im pulling vac on my boost gauge ? boost gauge and BOV are tapped at the white TEE's
does anyone have pics of how your's are hooked up?
HatchNation #36
FF 13 best audio
FFW 13 best focus
kwg2371 is offline
Old 07-09-2013, 10:47 PM   #9
egbertnr
Focus Factor
egbertnr's Avatar
Fan#: 27383
I dont see where you are getting your boost/vac ref from. Where are you tapped into IM or line going to IM? I looked at all my old pictures and cannot for the life of me remember what I did before I switched to the Jay Racing IM.
egbertnr is offline
Old 08-16-2013, 04:52 PM   #10
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
What I Drive: 2001 ZTS, 2002 SVTF Turbocharged
FF Reputation: 6 svtf1417 Good Standing Member
No you did it right. There will be vacuum until the turbo supplies boost. one thing ill suggest though is a dedicated vacuum line for your blow off valve. just my 2 cents
[#1417] 2002 Sonic Blue SVT Focus
Born on June 25, 2002
2001 Silver ZTS Sedan - "Ol' Reliable"
svtf1417 is offline
