Issue with temps - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-28-2013, 09:13 AM   #1
BIMMERKID21
Fan#: 98852
What I Drive: 2001 Ford Focus ZTS Twilight Blue
Points 508, Level 10
Points: 508, Level: 10 Points: 508, Level: 10 Points: 508, Level: 10
Level Up 16% Completed
FF Reputation: 1 BIMMERKID21 Good Standing Member
Issue with temps
recently I had a long drive in high temps from North Dakota to Minnesota. Got stuck in rush hour traffic upon reaching the Twin cities area.... sitting around going no where in a hurry.. While sitting in that rush hour, car temp started heading towards the far right. Pulled over left it sit a while to cool off. Then I started up again and drove to Mall of America and did so on side streets at my first opportunity to exit the "parking lot" we call I-494/94, Left it sit a couple hours til the car was cooled down. Continued onto my final Destination in Southern MN without a hitch. Since then I've driven back up to western ND to get a few more things from my storage unit. Didnt have any problem up and back on the drive. The other day, I noticed the temp creeping up a bit.. Turned the fan on high then it went right back to usual running temps.
It has a brand new Thermostat in the coolant system. Any ideas whats going on?
Car is running just fine otherwise. Don't notice anything different with the way the car is running or idling..
Midwest Crew
BIMMERKID21 is offline
Old 07-28-2013, 11:58 AM   #2
focusdaily
focusdaily's Avatar
Fan#: 114250
What I Drive: 2014 SGM HB SE 5 Speed
Points 174, Level 3
Points: 174, Level: 3 Points: 174, Level: 3 Points: 174, Level: 3
Level Up 48% Completed
FF Reputation: 1 focusdaily Good Standing Member
I just had a similar problem, where it would overheat at idle on my 02 zetec. The low speed fans were not working, had to replace the low fan resistor. I got mine off amazon, dorman part 902-219. I would search the forums for overheat at idle, there are a lot of posts on the issue, guess its a common issue. Do some research but sounds like same problem if it only overheats sitting at idle. Hope you can figure it out, resistor was about 25 and easy to replace.
focusdaily is online now
Old 08-01-2013, 06:12 PM   #3
BIMMERKID21
Fan#: 98852
thanks for the tip.. ordered it in off amazon.. will let ya know what happens after I swap it out.
Midwest Crew
Old 08-01-2013, 07:09 PM   #4
focusdaily
focusdaily's Avatar
Fan#: 114250
Points 174, Level 3
No problem, did you do dome research? I found one post where they told the temps that your fans actually kick on. At first I wasn't sure it actually fixed it, but yesterday I finally confirmed the low fans kicked on normally. Also my plug wasn't bad but it seemed most peoples were. Good luck, hope that fixes it.
