Massive toe arms - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-20-2013, 12:06 AM   #1
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Points 7,472, Level 57
Points: 7,472, Level: 57 Points: 7,472, Level: 57 Points: 7,472, Level: 57
Level Up 61% Completed
Forum Activity 40%
Buy-Sell-Trade Rating: (8)
Massive toe arms
So I bought a set of Massive toe arms a few months ago. Been sitting around in their bubble wrap until now. Going to be installing them in the next couple weeks(finally) especially since having just lowered my car 1.5" I am getting significant wear on the very inside edge of the drivers side rear tire and only a little on the passenger. Pretty sure my toe is out of wack in the rear now. Haven't had a chance to get alignment yet but want to get these on first so they can dial it in.
Question is are both ends of the toe arms suppose to be adjustable? I can easily spin the heim joint at one end as well as the jam nut on both. But at the other end I cannot get the heim joint to budge(unthread). The jam nut moves a hair but the joint will not spin. This end of the arm also has 2 flat spots on the outside body of the arm. The end that spins has no flat spots and is perfectly round. Also was wondering which end goes towards the wheel and which end goes towards the center of the car since one end has the flat spots(for clearance???)? The directions say nothing about the flat spots or which end goes where but they do make it sound like both ends are supposed to spin.
Any answers are much appreciated.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
Old 07-20-2013, 12:31 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,331, Level 100
Points: 138,331, Level: 100 Points: 138,331, Level: 100 Points: 138,331, Level: 100
Forum Activity 53%
Buy-Sell-Trade Rating: (11)
I want to look at if I can get a chance.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 07-20-2013, 12:42 AM   #3
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 40%
....and I had no uneven wear issues b4 lowering. Now its just the inside 3/4" of the rear tire. The arms should fix it fine. Of course old suspension was really worn and original to the car.
Team Focalize
Hatch Nation #9
Old 07-20-2013, 01:10 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,940, Level 74
Points: 12,940, Level: 74 Points: 12,940, Level: 74 Points: 12,940, Level: 74
Level Up 23% Completed
Question is are both ends of the toe arms suppose to be adjustable? I can easily spin the heim joint at one end as well as the jam nut on both. But at the other end I cannot get the heim joint to budge(unthread). The jam nut moves a hair but the joint will not spin. This end of the arm also has 2 flat spots on the outside body of the arm. The end that spins has no flat spots and is perfectly round. Also was wondering which end goes towards the wheel and which end goes towards the center of the car since one end has the flat spots(for clearance???)? The directions say nothing about the flat spots or which end goes where but they do make it sound like both ends are supposed to spin. They are= one spin one way & the other spin backwards, to adjust your lenght.
The heim joints have a left & a right so you can lenghten or shorten the links. The rods them selfs have a left & right threads & one heim joint will be left hand thread & the other will be right hand thread. I have mine set up the same way on both sides, so you turn it to the right & it lenghtens it or turn it to the left & it shortens the link, which gives more toe. You will find just a 1/8 of a turn makes a difference for your toe adjustment. Make sure to use boots to protect your heim joints from dirt & debris= they don't like dirt at all. .05-.10 per side for rear toe & zero toe for the front is what I use.
felixthecat is offline
Old 07-20-2013, 01:19 AM   #5
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 40%
Thing is I can only get the heim joint on one end to turn in any direction(unthread). I can't get the other end to turn at all. So as it stands if I install them as they are I would have to unbolt them to adjust them which I shouldn't have to do. I was thinking both ends are suppose to unthread so you don't have to unbolt them. Just thought it was weird that on both arms the ends with the flat spots won't turn. Maybe they are stuck and I need to get out the channel locks or something?
Team Focalize
Hatch Nation #9
Old 07-20-2013, 01:26 AM   #6
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 40%
Vise grip pliers and a big screw driver ftw. The flat spot end seems to have more resistance to threading/unthreading.
So, flat spot end towards wheel or center of car?
Team Focalize
Hatch Nation #9
Old 07-20-2013, 01:27 AM   #7
felixthecat
w/ my magic bag
Fan#: 80663
I'd tape up the flap spots & use a open end wrench in a vise. They should turn on both sides. One turns counter clockwise & the other turns clockwise. Left & right threads. Get them working before you install them.
Old 07-20-2013, 01:34 AM   #8
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 40%
Already done but thanks. For some reason they were stuck like a mother. But with the vise grip pliers and a big screw driver through the heim opening I finally got them free. I had to pull like mad to get them loose. They are fine now and I didn't mess up the paint.
Team Focalize
Hatch Nation #9
Old 07-20-2013, 11:02 AM   #9
felixthecat
w/ my magic bag
Fan#: 80663
Thats great, that you got them unstuck. I wouldn't think they'd be that tight. Put both of them on the ground side by side & look how the ends thread in & out. I have mine going the same way on both sides. For me its easier to think about the adjustments, cause they are twisted the same direction for the same adjustment on both sides.
