rear (bank 2) oxygen sensor code - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2013, 11:57 AM   #1
jimnich
Fan#: 116560
What I Drive: 2002 silver se
FF Reputation: 1 jimnich Good Standing Member
I have a 2002 SE with the SPI motor. I have been driving with the cel on. I plugged in a obd2 code reader and found out the rear o2 sensor was bad. I also just replaced the pvc elbow due to a split in it causing a leak and giving me a rough idle. After replacing the split elbow i have taken notice of my cel off and other times back on. Can this be related in any way or is it just actually a bad o2 sensor? I am new to the Focus world and plan to do more to also give me some more ponies under the hood. Any and all help/ advice would be appreciated. Thanks
jimnich is offline
Old 07-09-2013, 12:15 PM   #2
bile0026
bile0026's Avatar
Fan#: 97349
What I Drive: 2009 Amber Gold Metalic Focus
Points 380, Level 7
Points: 380, Level: 7 Points: 380, Level: 7 Points: 380, Level: 7
Level Up 60% Completed
FF Reputation: 7 bile0026 Good Standing Member
There are other things that can cause a "bad" O2 sensor such as a misfire. Misfires can cause a rich condition and the O2 sensor tries to get the computer to correct the problem but if it can't it throws an O2 sensor code or it gums up the sensor with the extra fuel in the exhaust. Also, I have seen exhaust leaks cause O2 sensor problems.
2009 Ford Focus Sedan SE--Amber Gold Metallic--FS Cool-flo intake, 17" Black Kazera Rims with Potenza S-04PP, Custom 2.5" Exhaust.
bile0026 is offline
Old 07-09-2013, 03:53 PM   #3
Richard Bridgette
Fan#: 99824
What I Drive: SCCA GT-1 road race Mustang
FF Reputation: 2 Richard Bridgette Good Standing Member
Rear O2 sensor
I believe the rear O2 sensor basically monitors how well the catalytic converter is functioning, rather than rich or lean fuel mixture, which I believe is the main function of the front (bank 1) O2 sensor.
Richard Bridgette is offline
Old 07-09-2013, 03:58 PM   #4
bile0026
bile0026's Avatar
Fan#: 97349
Points 380, Level 7
They are all connected. And if the amount of exhaust is effected it will effect the cat which will effect the O2 sensor.
Sent from cyberspace
bile0026 is offline
Old 07-09-2013, 05:42 PM   #5
jimnich
Fan#: 116560
Thanks for the input. I also hear the o2 sensor can be taken out and cleaned off rather than be replaced. Anyone have any helpful tips on that?
jimnich is offline
Old 07-10-2013, 11:30 PM   #6
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Did you happen to monitor the voltage on the downstream O2 sensor? If so what did you see? Also if you are worried about a catalytic converter being plugged, you can take an infra-red thermometer and measure the difference in the inlet and outlet temperatures of the cat and if there is a noticeable difference in the two that signals a bad cat. Also a visual inspeciton inside of the cat is a good way to check to see what condition the substrate is in. I've had success cleaning some O2 sensors with electronic cleaner depending on the amount of build up. I would be careful using anything else because the O2 does sample internally and externally. Dont completely discount the wiring to and from the O2 sensor sometimes it degrades over time and is a good idea to check it with a multi-meter. Bile0026 is correct in that a leak can cause this code as well. Check for cracks in the exhaust manifold, around welds and gaskets or even possibly rusted out holes in the exhaust. Hope this helps.
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
