2001 zx3 slight hesitation/surge under light accel - Page 2 - Focus Fanatics
Old 07-03-2013, 11:04 AM   #11
Milton
Fan#: 89715
FF Reputation: 4 Milton Good Standing Member
Unless I am wrong:
- The air is flowing from the valve cover into the air box.
- Atmospheric air also flows into the air box.
- All air in the air box flows from the air box, past the MAF and into the combustion chambers.
- The MAF meters all air flowing from the air box to the combustion chambers.
Am I wrong?
Milton is offline
Old 07-03-2013, 11:35 AM   #12
akatagyourit
Fan#: 113242
What I Drive: 2001 Red ZX3
FF Reputation: 1 akatagyourit Good Standing Member
Originally Posted by Milton View Post
Unless I am wrong:
Am I wrong?
If I plug the hose of the valve cover port with my finger it has a suction at idle, and lessens as the rpms go up. If that is the case though then we're taking air that has been metered pulling it through the system and reintroducing it back to the maf as dirty oily air on maf sensor. So we'd be causing the motor to run richer.
akatagyourit is offline
Old 07-03-2013, 11:43 AM   #13
jdmzx5
Fan#: 116056
What I Drive: 2004 Silver Focus ZX5 Svt Eap
FF Reputation: 1 jdmzx5 Good Standing Member
The fresh air hose pulls air from the air filter box into the valve cover through the crank case into the pcv valve through the intake. The pcv valve is a metered leak the pcm software is programmed for. The cone filter on the maf requires a reprogram due to the increased air flow to the maf.
jdmzx5 is offline
Old 07-03-2013, 12:01 PM   #14
lowzts
lowzts's Avatar
Fan#: 115627
What I Drive: 02 liquid grey zts mach audio
FF Reputation: 1 lowzts Good Standing Member
I have same the same issue with my 02 zts with zetec. I put a "breather" filter on the end of my valvr cover breather and have been running a cone filter as mentioned above for about 4 yeats and have not had this issue. I have been told that the DPFEE sensor can be bad?
Sent from my ZTE N9120 using FF Mobile
lowzts is online now
Old 07-09-2013, 05:49 PM   #15
lowzts
lowzts's Avatar
Fan#: 115627
I changed the camshaft positioning sensor and the crankshaft positioning sensor then "poof" hesitation stopped. Cost like $60 and some patience. Hope this helps
