Car engine shaking, squealing and giving off burning smell - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-01-2013, 10:28 AM   #1
DaiDreamer2008
Fan#: 116307
What I Drive: 2001 red zx3
FF Reputation: 1 DaiDreamer2008 Good Standing Member
I have a 2001 Ford Focus zx3 with about 145000 miles, bought it about a year and a half ago and has almost always had the engine light on. Never had any problems with it until this morning. Tried to drive it and it started giving off this burnt plastic/rubber smell and the engine started shaking pretty hard. It shakes at idle, when driving, when stopped. It doesn't matter how fast or how slow, the shaking is constant. A squealing noise from under the hood also started up and worsens as it accelerates. Engine light starts blinking on and off after all of this. Just changed the oil about 3 or 4 days ago so I know it has nothing to do with the oil level. Brought it to the shop this morning but they wont be able to look at it until tomorrow. Any ideas?
DaiDreamer2008 is offline
Old 07-01-2013, 11:46 AM   #2
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,858, Level 25
Points: 1,858, Level: 25 Points: 1,858, Level: 25 Points: 1,858, Level: 25
Level Up 58% Completed
FF Reputation: 16 ShoOff Great Standing Member
belt?
Steeda CAI, Steeda STS, Magnaflo Cat Back Exhaust, Injected Tuner, Cobb Rear Motor Mount, TTR Upper Motor Mount, Injected 180 T Stat
ShoOff is offline
Old 07-01-2013, 11:48 AM   #3
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 956, Level 16
Points: 956, Level: 16 Points: 956, Level: 16 Points: 956, Level: 16
Level Up 56% Completed
FF Reputation: 3 CotyM Good Standing Member
It's hard to tell what exactly is going on with out engine codes... But iirc, a flashing check engine light indicates severe misfire or knock, witch is consistent with running rough and a bad smell. As for the squealing and smell that could be anything... My guess would be the belt... But like I said, it could be anything...
Also, come to think of it, it could just be a seized pulley on the belt altogether, I mean, this would cause a burning smell, the belt would squel and the engine light could flash because the engine is having trouble running due to drag...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
Old 07-01-2013, 11:54 AM   #4
ShoOff
ShoOff's Avatar
Fan#: 109590
I would guess with the squealing and the burnt rubber smell is that your belt is slipping and burning
ShoOff is offline
Old 07-01-2013, 07:44 PM   #5
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
.............and fix the light. It may be you could have had warning of something going bad but leaving that light alone has now cost you damage because you didn't.
amc49 is offline
Old 11-06-2013, 04:18 PM   #6
DaiDreamer2008
Fan#: 116307
So I know this is a bit late...I actually forgot I posted this. So lets bring everything up to speed. Brought my car to the shop and they said it was my ignition coil. They replaced it and it ran normally after that. Now I have a new problem. This is 4 months later, I have discovered a rapid coolant leak coming from the right side of my engine. One of my friends diagnosed it as a leaking thermostat housing and/or gasket. I plan on replacing it friday but I have been having to drive it with this problem for the past week. It doesn't pver heat as long as I keep coolant in it which I have to do every time I go to drive the car. Other than the leak, it runs fine.....until today. Today I started it up and its giving me the same symptoms it did when my ignition coil failed. Do you think that this could be something else possibly realted to the coolant leak or is it my brand new ignition coil going oit again????
Old 11-06-2013, 04:58 PM   #7
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
Fix known problems first.
You need to quit deferring necessary repairs, they never fix themselves and they often cause much more expensive problems by waiting.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 11-06-2013, 06:15 PM   #8
Highball116
Fan#: 112564
What I Drive: 2005 Red ZX4
Points 650, Level 12
Points: 650, Level: 12 Points: 650, Level: 12 Points: 650, Level: 12
FF Reputation: 3 Highball116 Good Standing Member
Also, when your check engine light turns on, get the code. Autozone reads them for free and gives you the definition on a receipt paper.
Toby
Highball116 is offline
Old 11-06-2013, 06:55 PM   #9
Elder
Points 13,375, Level 75
Points: 13,375, Level: 75 Points: 13,375, Level: 75 Points: 13,375, Level: 75
Level Up 32% Completed
Ignition coil is fairly close to the thermostat, coolant spraying all over that could def. cause ign. issues...
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 11-07-2013, 08:21 AM   #10
Forum Activity 40%
More to this than being told, original fault was a coil (?) alone 'and it ran normally after that.' but no way not ever does a coil make squealing noises. Somebody is leaving out details that quite possibly could tilt the outcome. No way on earth would anyone diagnose a coil by squealing noises.
amc49 is offline
