svt driver side door wont open - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-16-2013, 08:08 PM   #1
playaplaya81
playaplaya81's Avatar
Fan#: 106583
What I Drive: 2003 ford focus svt
Points 308, Level 6
Points: 308, Level: 6 Points: 308, Level: 6 Points: 308, Level: 6
Level Up 16% Completed
FF Reputation: 1 playaplaya81 Good Standing Member
So today my driver side door wont open last time I drove the car was yesterday and it was fine. I was able to get the door open a little bit but it wont come all the way open, when I hit the unlock button on the door or fob the drivers side clicks 3 times and sounds like it wants to unlock but wont. The lock and door handle inside the car will not budge outside the handle still pulls like normal.
If anyone has had this issue and has any tips your help would really be appreciated.
playaplaya81 is offline
Old 06-16-2013, 08:26 PM   #2
playaplaya81
Fan#: 106583
Points 308, Level 6
Also the key will not open the door either
Old 06-16-2013, 11:19 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,164, Level 74
Points: 13,164, Level: 74 Points: 13,164, Level: 74 Points: 13,164, Level: 74
Level Up 79% Completed
Forum Activity 40%
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat".
zetecDon is online now
Old 06-17-2013, 12:37 AM   #4
Points 3,386, Level 36
Points: 3,386, Level: 36 Points: 3,386, Level: 36 Points: 3,386, Level: 36
Level Up 24% Completed
Forum Activity 53%
Try pulling the inside door handle fixture loose from door panel. One screw under the plastic plug and rotate handle out and back to free it at the back. Pop loose the cable end and remove it from the handle. Then take a pair of visegrips and grab now exposed cable carefully close to the housing and push back INTO the housing little by little. Take small bites so cable does not flex uselessly, and don't bite deep into cable to avoid damaging it. You may have to work it in/out for a bit. Mine came unjammed that way. The lock assembly sometimes locks up and refuses to unlock, thinking the handle unlocks at same time lock locks to seize the works up.
amc49 is online now
