Map Light LED Mod - 2007 Hatchback - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-09-2013, 07:41 PM   #1
wkampenhout
wkampenhout's Avatar
Fan#: 114078
What I Drive: 2007 Yellow ZX3
FF Reputation: 1 wkampenhout Good Standing Member
I wanted to change my Dome and Map lights to LED Blue Dome and White Map lights. At superbrightleds.com you can get the bulbs needed, but the Map lights needed a bit of work to make work.
Here are the bulbs I purchased:
http://www.superbrightleds.com/morei...edge-base/206/
To Remove the fixture, simply
1 - Use a small screw driver and pop the fixture open, and then maneuver it until it comes free.
2 - Pop the clips open and pull the fixture in half.
To replace the bulb with an LED Bulb:
3 - Slide the brass positive connection to their side of the bulb and remove the bulb.
4 - unwrap the wires from the LED and clip off the last half of the wedge base (this is so the wedge base isn't too long)
5 - Identify the positive and negative wires (positive has a resistor connected inside the bulb)
6 - put the bulb in the socket and feed the negative wire through a little hole
7 - Hot glue the wedge of the bulb to the socket (DO NOT LET THE HOT GLUE TOUCH WIRES this creates a potential for it to melt)
8 - Pull the Brass Positive connection over the LED base and wrap the positive end of the LED around the little wing. I didn't solder it in in case I want to replace the bulb.
9 - Clip the fixture back in and make sure the housing that goes around the bulbs goes in how it was initially pulled out.
How you guys enjoy!
wkampenhout is offline
Old 06-09-2013, 09:25 PM   #2
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,437, Level 21
Points: 1,437, Level: 21 Points: 1,437, Level: 21 Points: 1,437, Level: 21
Level Up 37% Completed
FF Reputation: 2 Miztaken1312 Good Standing Member
Well done!
Excellent choice on the hot glue. I was advised to use it to put my grille back together (instead of epoxy) after the previous owner decided not to learn how to take it off properly and broke 3 of the 6 tabs on it.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 06-09-2013, 10:47 PM   #3
Gadabout
Gadabout's Avatar
Fan#: 114774
What I Drive: 2006 Vermillion Red ZX4 SE
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 4 Gadabout Good Standing Member
I bought the wedges a few weeks ago, and didn't notice they wouldn't fit (w/o modding) til it was too late. Way to go for figuring out! Really wish there was a simpler replacement tho.
“Things work out best for those who make the best of the way things work out.” - J Wooden
Team Duratec #42
Gadabout is offline
Old 06-09-2013, 11:18 PM   #4
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
Points 2,134, Level 27
Points: 2,134, Level: 27 Points: 2,134, Level: 27 Points: 2,134, Level: 27
Level Up 90% Completed
Forum Activity 21%
Buy-Sell-Trade Rating: (13)
That's one way of doing it!
I used to have proper replacement bayonet LED bulbs that actually worked. They were from Vleds and I guess they had bridge rectifiers (dual polarity), it's been three years now, so I'm not sure if they still make them like that anymore.
I bought an EDM light that uses different bulbs, I sold the old bulbs another member and they worked for him too.
Sniper Focus is online now
Old 06-10-2013, 09:22 AM   #5
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,909, Level 59
Points: 7,909, Level: 59 Points: 7,909, Level: 59 Points: 7,909, Level: 59
Level Up 80% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
Buy-Sell-Trade Rating: (15)
I bought some leds that were plug and play for my maps lights. I will have to see if i can track the part number down or where i ordered them from...
rambleon84 is offline
Old 06-10-2013, 09:34 AM   #6
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
Points 23,494, Level 94
Points: 23,494, Level: 94 Points: 23,494, Level: 94 Points: 23,494, Level: 94
Level Up 15% Completed
Forum Activity 23%
FF Reputation: 23 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (58)
FYI the hot glue will not melt. You need 250-380*F to melt the glue. If that dome light got to 250-380* or the wires, you'd have a much bigger problem.
The glue will never melt, I've used it hundreds of times on circuits.
Neither will plastidip, FYI. You're ALL fine using any of it to seal the wires.
Daily: Audi S4 b5 | Project: Turbo ZX3
LED Conversions | Vinyl Carbon Wrapping | Powdercoated Valve Covers
starfuryt550 is offline
Old 06-10-2013, 01:14 PM   #7
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Points 11,527, Level 70
Level Up 70% Completed
Buy-Sell-Trade Rating: (48)
Shoulda just got these, they are plug and play
http://www.superbrightleds.com/morei...-wide-angle/3/
These are more expensive, but are also plug and play and it's what I am using for map lights
http://www.superbrightleds.com/morei...9-led-tower/9/
Hatch Nation #8
katiekay is offline
Old 06-10-2013, 03:39 PM   #8
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 38%
yep, thats the style i have! id only be going through the trouble of gluing modding if it created a bright or better output for the map lights
Old 06-10-2013, 07:34 PM   #9
Sniper Focus
Fan#: 84221
Forum Activity 21%
I was about to say, I've been using hot glue for years on stuff like this.
Old 06-16-2013, 02:48 PM   #10
wkampenhout
Fan#: 114078
Should have gone with these
This is what everyone should have gone with. I guess thats what I get for getting the bulb the manual told me to get without ever popping the Map lights open to see whats inside.
Irregadless, it was a good education about learning how to hook up LED's, do mods, etc. I wouldn't recommend the single bulb LED's for map lights, as they are super dim and don't really do you any good.
