I'm new on the forum and have some A/C questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-13-2013, 11:44 AM   #1
roberted5
Fan#: 115674
What I Drive: 2006,Black,LS
FF Reputation: 1 roberted5 Good Standing Member
Symptoms when cool outside,mornings evenings cools very well,probe in vent reaches 42-46 degrees but if I speed up,tempature goes up and blower warmer air.At high speeds less cooling.
During 12-7Pm probe will not get below 54-64 and does best at slower speeds.
Air tempature fluxuates.
I had it sucked a refilled to proper specs.
I'm tempted to buy every major part for A/C and start with new components.
Dealer that sells many Focuses says it sounds like compressor,but if more air is going over condenser is causing temp to go up,could it be the culprit.
I could try one component at a time but it must be sucked,filled with oil,the refilled and there goes another day.
I'm at wits end and am thinking of just replacing compressor,Dryer,condenser and Expansion device.
roberted5 is offline
Old 06-13-2013, 04:42 PM   #2
CriticalMass
Fan#: 63989
What I Drive: 2009 Focus Coupe SES, Silver
Points 372, Level 7
Points: 372, Level: 7 Points: 372, Level: 7 Points: 372, Level: 7
Level Up 44% Completed
FF Reputation: 2 CriticalMass Good Standing Member
Have heard a lot of complaints from Mustang owners about this in recent years.
check over on Stangnet and do a search.
2009 Ford Focus Coupe SES -- What I don't know about modern cars would fill up a good sized country, but what I don't know about 50's and 60's Ford engines, would fill up a 4 oz glass.
CriticalMass is offline
Old 06-13-2013, 08:10 PM   #3
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,085, Level 67
Points: 10,085, Level: 67 Points: 10,085, Level: 67 Points: 10,085, Level: 67
Level Up 9% Completed
Forum Activity 40%
Buy-Sell-Trade Rating: (41)
Funny I have same problem in my ford escape
pasta is online now
Old 06-14-2013, 06:36 AM   #4
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
How about low refrigerant. Get some gauges. What's happening is that you are at say 35 psi on the low side at idle, but when you speed the engine and compressor up- it drops below 23 psi which cuts off the compressor to prevent ice from collecting on the evaporator. Then you get warm air until you slow down. You might not even feel the compressor kicking in and out while you're driving at higher speeds. If you get a full set of gauges, check the high side also (but not at the same time unless you have really expensive gauges) and see what pressure the compressor is pumping up to. If it's not over 200 psi, then yes, you might have a bad compressor.
Yeah, they'd like to blame it on the compressor and charge you $1500 for the repair. I know, I had a friend who took a Volvo in for AC repair- $1100 later it was fixed. It's a good thing he's a lawyer and can afford it.
