What to upgrade - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 05-20-2013, 10:45 PM   #1
xxe,ixx
Fan#: 114878
What I Drive: 2001 White zx3
FF Reputation: 1 xxe,ixx Good Standing Member
What to upgrade
I'm not even quite sure it's possible, I recently ( a year ago ) bought a 2001 zx3 zetec and I'm really not sure what to upgrade on it now. What I really want is to have some serious acceleration and I want to, if possible, make rpms lower in 1st gear but still achieving a higher speed. For example when I take off I want to be able to last til 30~ under 4 grand rpms in first gear. The guy I bought it off worked at a shop and was big into upgrading the car also, he did a few flex pipe repairs (annoying sound), aftermarket cams, borla exhaust, lowered car with eibach springs. What would provide me with these?
oh and a focuswerks head
xxe,ixx is offline
Old 05-29-2013, 08:36 PM   #2
Pb-foot
Pb-foot's Avatar
Fan#: 62873
What I Drive: 2004 Silver 3dr SVTF w/EAP
FF Reputation: 1 Pb-foot Good Standing Member
Not sure what you are asking... are you saying the car already has all the things listed in the last sentences of your post?
Stockholm Getaway - 465 hp Cosworth vs Supra - see it on YouTube
Pb-foot is offline
Old 05-29-2013, 11:27 PM   #3
JFrye
JFrye's Avatar
Fan#: 54896
What I Drive: 2000 ZX3, 99 Dodge 3500 w/Cummins
FF Reputation: 3 JFrye Good Standing Member
I believe he is saying that stuff has been done. But he is asking if its possible to run 50-60 mph in first gear.
2000 Silver ZX3. 2.0 Zetec, Auto trans with 3.90 gears. 14 inch steelies, P185/65R14 Firestone Affinity Touring Tires. Eibach Sportlines, Massive Upper Strut Bar, BBK 65mm Throttle Body, FSWerks 4 to 1 Header, Custom 2.5 inch into 3 inch exhaust.
JFrye is offline
Old 05-30-2013, 12:16 AM   #4
ViperThreat
Moderator OF DOOM
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
FF Reputation: 8 ViperThreat Good Standing Member
you arent going to get any "serious acceleration" unless you get into Forced Induction. A supercharger will get you into the mid to high 6 second range, a proper turbo setup will get you into the high 5s without too much engine work.
I highly reccomend the FSWERKS turbo kit:
http://www.fswerks.com/collections/t...oled-2003-2007
You will also need to upgrade your clutch (and probably flywheel if you have not done so already. Im not sure what cam was installed, but that may need to be reverted to stock depending on the turbo-kits tuning requirements.
As far as the gearing goes, is your focus automatic or manual?
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
ViperThreat is offline
Old 05-30-2013, 12:27 AM   #5
02svtf300
02svtf300's Avatar
Fan#: 83769
What I Drive: 2002 sonic blue SVT(moded)
FF Reputation: 2 02svtf300 Good Standing Member
As fare as throttle response... Your could alway do a larger TB and underdrive pullies... Aluminum flywheel... Better rubber on the ground... Hell spray it hehe:cool:
Sent from my HTC6435LVW using FF Mobile
02 sonic blue svtf...< modified addiction < DD
88 bronco II (x2)... < the twins
00 yamaha banshee... <will be the end of me
02svtf300 is offline
Old 05-31-2013, 01:03 AM   #6
xxe,ixx
Fan#: 114878
Thank you for the replies I apologize for not specifying what had already been done to the car. Currently on the car there are lowered eibach springs, a 2.5" borla exhaust, focussports header (not even sure about this just has the logo and a bill that says focussports header), adjustable cams, aluminum flywheel, racing clutch (all my dad told me cuz he was payin for it, personally bullshit it shifts like a mofo), and a built engine. There's currently ANOTHER flex pipe leak.
NOTE: I'd also like to know what you guys think of the Wings West WRC body kit. I absolutely love the WRC wing like markko martin's focus has. The front bumper and thoughts on it, doesn't stick out enough maybe?
EDIT: How would a throttle body benefit me?
EDIT 2: Oh yeah just threw on a massive CAI system in.
Edit 3: Manual
xxe,ixx is offline
Old 05-31-2013, 12:52 PM   #7
Pb-foot
Pb-foot's Avatar
Fan#: 62873
You really have to change final drive ratio if you want to go faster in each gear, but then it will not be as quick to get there... it's either fast or quick with gears, not both. The only way to go faster AND quicker is power, but the Zetec is not built to go 9K rpms, so you should build for torque.
Lightening the drive train is a good way to free up some torque. You already have lighter trans componenets, so try a crank UDP, remove the AC pump, and get the lightest wheels/tires and brake rotors you can get away with.
A larger TB will do almost nothing for you, unless you are prepared to increase flow through the head, get a larger MAF housing to go with it, and increase compression so you have a reason to do the other things. You can gain all the throttle response you could need by simply "porting" your stock TB.
Pb-foot is offline
