What Fords use the same engine cover - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-24-2013, 05:14 PM   #1
dbsimms63
Fan#: 110359
What I Drive: 2013 Performance Blue Titanium 5dr
Points 1,824, Level 25
Points: 1,824, Level: 25 Points: 1,824, Level: 25 Points: 1,824, Level: 25
Level Up 24% Completed
Forum Activity 6%
FF Reputation: 2 dbsimms63 Good Standing Member
Since I don't want to spend $70 for a "new" engine cover, I thought I would go to some local salvage yards and see if I could find one. Only problem is I don't know what other vehicles with the 2.0L Duratec had the same/similar engine cover. Having more than one vehicle to look for will greatly increase my chances for success. Could anyone shed some light on this for me please?
Thanks in advance!
dbsimms63 is online now
Old 05-24-2013, 05:22 PM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,910, Level 76
Points: 13,910, Level: 76 Points: 13,910, Level: 76 Points: 13,910, Level: 76
Level Up 65% Completed
Forum Activity 8%
Buy-Sell-Trade Rating: (18)
As for being on the Focus, only early Titanium models had them.
SkyPilot is offline
Old 05-24-2013, 05:24 PM   #3
dbsimms63
Fan#: 110359
Forum Activity 6%
So no other Ford model, Escape, Fusion, etc., used a similar cover?
Old 05-24-2013, 07:57 PM   #4
Points 10,249, Level 67
Points: 10,249, Level: 67 Points: 10,249, Level: 67 Points: 10,249, Level: 67
Forum Activity 37%
The Escape with 2.0 L ecoboost, or the Fusion 2.0 L at least should also possibly fit as long as the stud locations are in the same place, until some one tries it it's hard to tell.
The ST engine cover looks identical size wise to the N/A, but says ST on it so you'd probably not want it either. The only Ford to use the 2.0 L GDI engine in North America is the Focus however, therefore it's the only one guaranteed to work with the correct bolts/ studs.
suss6052 is online now
Old 05-24-2013, 08:21 PM   #5
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
My wife has an escape with the 2.0 EB and the cover is not the same as the focus cover, it looks like the ST cover w/o the ST logo on it.
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 05-24-2013, 08:31 PM   #6
Forum Activity 37%
The top design might be different, although my question was are the bolt/ stud locations in the same place on the engine (underneath the cover) to where it might work, if not, then no there is no cover that would fit other than the one for the Focus.
Old 05-25-2013, 04:29 AM   #7
I Bleed Ford Blue
Fan#: 94113
What I meant was the escape/fusion 2.0 EB cover has the holes in the same spot as the ST cover, so even if it fit the focus engine, you won't be able to access the dip stick or oil fill cap w/o removing it first.
To the OP, why not just buy the correct cover, they are only 60 bucks from partscheap.com and it even comes with the correct mounting hardware. If you buy from a dealer or elsewhere, you may have to source your own hardware and it costs more.
L-CCC #18/HOIA #37
Old 05-25-2013, 05:30 AM   #8
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
I can't believe this thread has gone on this long.
No other Ford uses the same engine the focus has, so no, no other model will have an engine cover that fits.
end of story.
Some Guy From NY is offline
Old 05-29-2013, 04:57 AM   #9
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
Forum Activity 7%
FF Reputation: 3 flyboyike Good Standing Member
Never mind that, I can't believe that someone who can afford a brand new car would rather spend a day digging through a junkyard than spend $70 (not $700) on the correct part.
flyboyike is offline
Old 05-29-2013, 09:44 AM   #10
dbsimms63
Fan#: 110359
Forum Activity 6%
Hey I try to spend my money wisely, and if I could get the same part at a nearby salvage yard, then why not be a smart consumer and get the thing for less? I was going to paint it and customize it anyway, but now I've found a company which may make a custom stainless cover for around the same amount as the stock OEM piece, so I'll probably go that route.
BTW, don't have to "dig" around a junk yard, you put in an online request and they pull the part for you. Pretty easy and hassle free.
