Installing solid shift base inserts on 08-11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > MK2 Interior Mods & Upgrades
MK2 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2008-2011 Focus.
Old 05-14-2013, 01:37 PM   #1
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Points 3,885, Level 39
Points: 3,885, Level: 39 Points: 3,885, Level: 39 Points: 3,885, Level: 39
Level Up 57% Completed
FF Reputation: 13 mac.mogul Great Standing Member
I recently purchased solid shift base inserts from cedwards89 in THIS thread and while he does not have many pieces left, if you're thinking about buying them they WILL work on mk2 and here is how to do it.
NOTE: I had originally installed them incorrectly, so these pics are of the inserts installed correctly but I do not feature the stock hardware.
You will need:
10mm socket that has at least an 8" long extension to reach down inside the console
6mm socket for removing the hex head screws on the sides of the console
A long reach, flat-head screwdriver
20 minutes
Step 1: Getting started
Get comfy and remove your center console. [Click links for pics]
Before
After
Step 2: Accessing the shift base
Using your long reach 10mm socket, remove the retaining nuts on the shifter base HERE
Once removed, use your long reach flat-head screwdriver and push it inbetween the stock metal insert and the rubber surround and pry the metal part out. They are easily removed and easily dropped if you have butterfingers.
Using your flathead screwdriver, pry off the covers on the sides of the console to access the hex-head screws that connect the base to the console. HERE
Once these are removed you can now lift the base assembly and remove the rubber bushings if they did not come out with the metal inserts. Pro-tip, it's much easier if you reach your hand under the assembly like THIS to pull the rubber bushings out from the bottom of the base.
Step 3: Insert your inserts (this is where I goofed on the first try)
Place the inserts into the existing base holes with the flat side up. Pro-tip, it is MUCH easier to complete the installation if you press the inserts into the plastic base BEFORE you position it onto the floor bolts. The forward-most inserts will take some doing as it is akin to pushing a round peg through a square hole but they will fit correctly.
You can see the inserts in the base HERE
Step 4: Putting it all together
Tighten everything back up the way you found it, duh.
Road Test: How does it feel?
In the thread where you see lots of SVT guys raving about these inserts, it's likely they DO notice a huge difference in shifting feel because the SVT base is stamped metal while ours is plastic. Plastic is softer than metal so we won't experience the same kind of "feel" that they are talking about; HOWEVER, I did notice that the gears engage much more solidly and the knob no longer "shakes" while cruising in 4th gear.
Well worth the 40 bones. Go buy the remaining sets of NON-SVT inserts from this guy and if he runs out, request that he make some more for the 2nd Gen crew!
2011 SES 5spd #006 >> SR #213
mac.mogul is offline
Old 05-14-2013, 02:58 PM   #2
PSUrivie
PSUrivie's Avatar
Fan#: 67329
Points 7,033, Level 55
Points: 7,033, Level: 55 Points: 7,033, Level: 55 Points: 7,033, Level: 55
Level Up 42% Completed
Buy-Sell-Trade Rating: (10)
Nice write up!!!
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 05-14-2013, 09:10 PM   #3
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Pics
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 05-15-2013, 12:09 PM   #4
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
FF Reputation: 7 indy_11 Good Standing Member
Originally Posted by Indy'sexclusiveZx3 View Post
Pics
they're in the write up. clink on the bolded links...
good to see they do something though. If had $40 i'd spend it on these. Appreciate the write up
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 05-24-2013, 04:21 PM   #5
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,382, Level 20
Points: 1,382, Level: 20 Points: 1,382, Level: 20 Points: 1,382, Level: 20
Level Up 82% Completed
FF Reputation: 2 Miztaken1312 Good Standing Member
And thanks to this, mine have just been installed. Thanks Mac!!
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 05-24-2013, 06:09 PM   #6
PSUrivie
PSUrivie's Avatar
Fan#: 67329
I just got a set in the mail. Got a little project for tomorrow :)
PSUrivie is offline
Old 05-24-2013, 08:39 PM   #7
badazz2010focus
Fan#: 78166
Points 18,613, Level 86
Points: 18,613, Level: 86 Points: 18,613, Level: 86 Points: 18,613, Level: 86
Level Up 53% Completed
Forum Activity 8%
how much where they or was that in the link to?
badazz2010focus is offline
Old 05-24-2013, 08:42 PM   #8
Miztaken1312
Fan#: 74993
It's in the link. $40 for 4.
Old 05-24-2013, 09:45 PM   #9
badazz2010focus
Fan#: 78166
Forum Activity 8%
oh ok that's not bad :)
Old 05-24-2013, 10:43 PM   #10
Albrtd3
Fan#: 109544
What I Drive: Black 2008 Focus
FF Reputation: 1 Albrtd3 Good Standing Member
These instructions helped a ton, big thanks!
Albrtd3 is offline
