Temp Gauge Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-14-2013, 02:32 AM   #1
renee
Fan#: 104406
What I Drive: 2005, tan, ZX4
FF Reputation: 1 renee Good Standing Member
Temp Gauge Question
sorry if this has been asked before but I took my Ambien and it's kicking in. Sorry if I don't make sense but here's my question:
My 2005 ZX4 when started, the temp gauge almost immediately goes into the middle position. Now, granted I live in Arizona but it's done this for a while. Is that normal?
renee is offline
Old 05-14-2013, 03:23 AM   #2
freeclowns
Fan#: 49643
What I Drive: 2001 red zx3
FF Reputation: 1 freeclowns Good Standing Member
I had a problem like this with my temp gauge.. Tho when I just turned the key on it would say the car was over heating.. Now this is after the car has been sitting all night long..
Try replacing your cylinder head temperature sensor. that is what fixed my problem... I hope this helps...
freeclowns is offline
Old 05-14-2013, 05:55 AM   #3
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
^^ There is only one temp sensor for the engine, and it's in the middle of the cylinder head between #2 and #3 spark plugs. You'll want to get some nickel anti-seize, or anti-seize that is good for 1500 deg or better.
Old 05-14-2013, 05:33 PM   #4
Elder
Points 13,419, Level 75
Points: 13,419, Level: 75 Points: 13,419, Level: 75 Points: 13,419, Level: 75
Level Up 43% Completed
'Almost immediately" is the question.
If it is at the bottom with the key on (engine cold), then goes up quickly & holds it's position afterwards, probably normal.
These sense temperature B4 the coolant heats up, because of the "cylinder head temp sensor" mentioned earlier. So it shows warm B4 you'll get heat on a cold day.
"Odo Trick" - where you hold the trip button while turning it on, then page thru functions by pressing the button - this will get you to a digital reading for actual temperature. If it matches outside temp. when cold, then goes up to a normal engine temp while running, all is OK!
Check it B4 trying parts...
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
