Wheels assistance. - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Sponsored By:
Tire Rack
Old 05-02-2013, 10:38 PM   #1
1slofofo
Adam
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3
FF Reputation: 6 1slofofo Good Standing Member
Wheels assistance.
So I'm taking half my vacation next week, and will take the rest later on and I plan on getting some wheels ready. I want 16's to use the stock tires (hardly worn anyways, cheaper to replace if I ever have to). Anyways, I found these that I really like: http://www.tirerack.com/wheels/Wheel...All&sort=Price
Now looking at the specs, they have a 48 mm offset. Will I need spacers or something to have them fit? I thought I saw the Focus has 49 or 50 somewhere. (Truly new at this but I'm tired of hubcaps.) Also, TPMS-wise, would wherever I go to mount them have that much trouble? Tirerack seems to make it seem like it'll be a huge hassle unless I buy from them. But I don't wanna dump nearly $200 on sensors.
Also, I'm going to school closer next year, so I won't have to worry about horrible streets, so these should hold up well. Any advice is appreciated, thanks all!
And quickly mocked up:
Simplicity is the ultimate sophistication.
1slofofo is online now
Old 05-04-2013, 10:40 AM   #2
1slofofo
Adam
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3
bump?
Old 05-04-2013, 10:50 AM   #3
jsr72
Fan#: 97393
What I Drive: 2012 Focus SE
FF Reputation: 4 jsr72 Good Standing Member
Stock offsets
Originally Posted by jsr72 View Post
15" steels are 46mm
16" steels are 50mm
16" alloys are 50mm
17" alloys are 50mm
18" alloys are 55mm
jsr72 is offline
Old 05-04-2013, 11:00 AM   #4
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
Buy-Sell-Trade Rating: (12)
You'll be fine with an offset of 48et. The 16's will provide the softest ride for you as well.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 05-04-2013, 11:39 AM   #5
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
FF Reputation: 46 dyn085 Great Standing Member
Under the assumption that you are using the OEM 215/55/16's, you can probably use 10mm spacers to make them more flush, and 15mm would put you close to rubbing with those tires.
If you're only concerned with whether or not they will clear the brakes, you will be fine.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 05-04-2013, 12:03 PM   #6
1slofofo
Adam
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3
Stock offsets
Thank you for the chart, very helpful!
Thanks, I didn't want issues with that, and I don't have any need for 17s other than looks. It handles phenomenally already.
Yeah, I will use my oem Conti's. Rough estimate of how much they'd potentially cost?
Old 05-04-2013, 12:09 PM   #7
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What, spacers? 5mm is usually around $80 a pair, I think 10's are around $100, 15's around $125-all before shipping. Look at trakplus.com to locate the correct part numbers and then search for pricing.
Before doing all of that though, you may want to read my spacer thread. Given what you've told me so far, I would recommend 5mm in front and 10mm in the rear...
September '13 ROTM
2014 FiST-
Old 05-04-2013, 12:28 PM   #8
1slofofo
Adam
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3
I'll look into it, maybe later on, though. I'll wait to see how these look.
Old 05-06-2013, 11:09 PM   #9
1slofofo
Adam
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3
What would happen if I threw 235/50R-17 tires on the car (obviously with 17 inch wheels instead)? I think they'd be taller, but would it be by much?
Old 05-07-2013, 10:40 AM   #10
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
If I am correct that the OEM 16" tire that you have is a 215/55/16 (I need you to verify for numbers to be correct), then you are looking at approximately 11.95mm of additional height (23.9mm additional total diameter) with the 235/50/17's. That gives you an additional 75.1mm of circumference and will throw your speedometer off by about 3.58%.
While I give relatively specific numbers, there is an amount of fudge factor due to tire pressure, vehicle loading, tire bulge, etc. This will also affect the ability to place spacers if you so wish.
September '13 ROTM
2014 FiST-
