Duratec cylinder head rebuild with pics - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-23-2009, 09:36 AM   #11
Vincent
Vincent's Avatar
Fan#: 62713
What I Drive: 2013 ST and 2005 Turbo ZXW
FF Reputation: 1 Vincent Good Standing Member
Nice build, it inspires me to do the same to mine. I didn't see it but what do you expect out of it?
2013 ST Performance Blue.
2005 ZXW - FS Stg 2 Turbo Kit, CFM 67mm t-body, Cosworth Stg 2 Cams, Crower Springs and Retainers, CFM Underdrive Pulleys, FS 2.25" Turbo back, EBC Discs, Hawk Pads, Eibach Sways, H&R Springs, Falken Wheels, VIS CF Hood
Vincent is offline
Old 07-23-2009, 11:42 AM   #12
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
Its just being rebuilt for functionality. No porting/polising/bigger valves or cams. This is a spare head that I have.
If I were to install it on a duratec motor I wouldn't expect much but reliability out of it because the D23 head flows much better.
Who knows...maybe I will source a D20 block for cheap and build something fun like a buggy.
afraziaaaa is offline
Old 07-27-2009, 11:09 AM   #13
ehancock
un1corn
ehancock's Avatar
Fan#: 53353
What I Drive: 2004 Twilight Blue D23 ZX5
FF Reputation: 14 ehancock Great Standing Member
Buy-Sell-Trade Rating: (7)
I didn't see any shots of the valve spring seats. At what point did you remove them? I just received my supertech valve spring kit and it came with valve spring seats. I figure i should replace them!
ehancock is offline
Old 07-27-2009, 11:27 AM   #14
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
Valve spring seats?
Do you mean valve seals?
I am not sure what you are talking about. Maybe the supertech parts use a seat that goes on top of the valve seal???
Post up a pic of what you are talking about, and I can probably tell you what you should do with it.
Unless someone else with the experience pipes in before that happens.
By the way, the head in this thread is a D20.
Old 07-27-2009, 12:13 PM   #15
ehancock
un1corn
ehancock's Avatar
Fan#: 53353
Needless to say, i'm a bit confused right now.
On your D20 head there were no metal spring seats that came out after the springs? Just the valve seals?
My supertech set came with springs, retainers, and valve seats. Not valve seals. They're cupped like they need to be on the bottom of the springs. I'll get some pictures when i get a moment today. I'm at work. Im sure it goes on the bottom of the spring. I'm going to be picking up my friend's ford workshop manual later today to research it. .
For now, here's the information that's on the box and on the packet of seats. I understand that you wont need all of this, but im posting it all anyways.
Sticker on packet of valve seats:
SEAT-DUR/1
Spring seat locator for SPR-TS1015 / Duratec engine
Posted on the box:
MAZDA/FORD 2.3 DURATEC SINGLE VALVE SPRING KIT
KIT# SPRK-TS/DUR-S
Spring: SPR-TS1015/SINGLE
Titanium Retainer: RET-TS5.5/T1
Spring Seat: OEM + SEAT-DUR/1
Seat Pressure: 55lbs @ 34.30mm installed height
Spring rate: 9.5lbs/mm
Spring coil bind: 20.7mm
Recommend Max Lift: 13.6
ehancock is offline
Old 07-28-2009, 03:29 PM   #16
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
I dunno. I'll start tearing my D23 head down today and let you know what I see in there.
I am sure someone else has already done one though...
And yes, you are correct about the D20 head. No seats.
Old 05-06-2013, 08:47 PM   #17
jw69er2007
Fan#: 114377
What I Drive: 06 black zx4
FF Reputation: 1 jw69er2007 Good Standing Member
the tappets fell out of my head
is there a way to put the tappets back in the right spots
jw69er2007 is offline
Old 05-27-2013, 04:00 PM   #18
jonnmandy
Fan#: 104831
What I Drive: 2005 Toreador red ZX3 Hatchback
FF Reputation: 1 jonnmandy Good Standing Member
thanks for the post. quick question though whats the difference between the D20 and the D23 head? Is it just the combustion chamber size? If i port and polish the D20 would it turn into D23?
jonnmandy is offline
Old 05-28-2013, 05:32 PM   #19
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
Points 28,322, Level 98
Points: 28,322, Level: 98 Points: 28,322, Level: 98 Points: 28,322, Level: 98
Level Up 98% Completed
Buy-Sell-Trade Rating: (29)
slightly larger port on the intake side. same exhaust, same CC size
==2012 Kona Blue Mustang V6==
==1972 Skylark==
Buickboy is offline
Old 05-28-2013, 06:06 PM   #20
jonnmandy
Fan#: 104831
so all you really need to do on a D20 head is port the intake ports a little more and then its a D23?
Similar Threads
FS Duratec race head w/cams/cg/sprgs/ret 0103VENOM Archive 10 08-25-2007 08:15 AM
General Specs on the 2.0L Duratec b16sir1991 General Technical Chat 0 04-18-2007 11:22 AM
General Specs on the 2.3L Duratec b16sir1991 General Technical Chat 0 04-18-2007 11:21 AM
General specs on the SPI b16sir1991 General Technical Chat 0 04-18-2007 11:20 AM
New Cylinder Head? jmltapp General Technical Chat 11 02-05-2004 03:28 PM
