getrag shims - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-30-2013, 02:44 PM   #1
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Points 12,389, Level 72
Points: 12,389, Level: 72 Points: 12,389, Level: 72 Points: 12,389, Level: 72
Level Up 85% Completed
Forum Activity 78%
Activity: 78% Activity: 78% Activity: 78%
FF Reputation: 10 SvviftSVT Great Standing Member
getrag shims
Hey guys (gals)
I need some help locating shims for the Getrag.
I will be trying my hand at installing the Torsen t-2 in my SVT this weekend, but cannot find shims anywhere.
Does anybody know what dimensions (diameter or whatever) that I need? or if shims for another vehicle can work.
I am aware that I need .006-.010" more than the shim currently in my car.
I am just wanting to have everything I need so I can try to do it in one go.
I am aware that I can go into a transmission shop and ask them, but I am trying to get all the correct information before I make that step to ensure I get the right ones...
Any help would be GREATLY APPRECIATED...
Thanks in advance,
Daniel
Track build has begun.
slow and steady.. but its going
SvviftSVT is offline
Old 04-30-2013, 02:45 PM   #2
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
Have you checked out CFM I am sure they have them.
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 04-30-2013, 02:49 PM   #3
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 78%
as far as whats listed.. the only shim they have is the "rear shock mount shim"
I know Bat Inc has a shim kit for like 70 bucks.. if possible, I would like to find them locally to save time.
Old 05-01-2013, 10:23 AM   #4
FordManSVT
FordManSVT's Avatar
Fan#: 44253
What I Drive: 2003 ZX3 SVT Euro in Comp Orange
FF Reputation: 1 FordManSVT Good Standing Member
How are you aware that you need a thicker shim if you haven't taken the trans apart and measured the bearing race clearance? I put a Torsen in my Svt and the stock shim put my in the correct bearing preload range. There are other people on here that have done the same. As far as finding a shim you will most likely have to go to a trans shop and look through what they have laying around. I was going to cut shims for a rear diff to fit if I had to use a different thickness.
FordManSVT is offline
Old 05-01-2013, 10:32 AM   #5
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 78%
Every how-to I have read stated that you wanted to preload the output shaft by .006-.010...
I was more wanting it as a safeguard so I could complete the install without any delays. Its already been over a month of not driving my SVT..
Hopefully, I am lucky like you and my stock shim works out.
Old 05-01-2013, 11:26 AM   #6
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,177, Level 34
Points: 3,177, Level: 34 Points: 3,177, Level: 34 Points: 3,177, Level: 34
Forum Activity 11%
FF Reputation: 4 qweesy Good Standing Member
so are you for sure doing it this weekend?
qweesy is offline
Old 05-01-2013, 11:29 AM   #7
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 78%
i am at least dropping it. and starting disassembly.
still working on getting the engine hoist (to relieve pressure on mounts and support the engine)
also a workbench and a shop press.
going to try to get the diff bearing on today. tomorrow, and/or Friday.
Old 05-01-2013, 11:41 AM   #8
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 11%
txt me your addy i would like to view this being i will eventually putting in the quaife in mine do you plan on working through the night on Friday, I know I work right next to where you live off 249 & Louetta
qweesy is offline
Old 05-01-2013, 11:45 AM   #9
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 78%
i will text you the addy...
and honestly, Friday night is date night with the lady. i am off during the day so i was going to get as much done as possible during the day.
taking her to a steakhouse then a movie...
been a while since we had a day to ourselves.
Old 05-01-2013, 11:55 AM   #10
FordManSVT
FordManSVT's Avatar
Fan#: 44253
You do want to preload the diff bearing but they are preloaded from the factory. Most time putting new bearings in doesn't make a lot if difference because it is the same spec bearing and race as you took out. That's why the stock shim usually works. You can get away without a shop press if you have race drivers and a hammer( swing press). I would get the factor red sealant for the case halfs. That stuff works best.
