Catalytic Converter modifications - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-25-2013, 10:25 PM   #1
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 2,325, Level 29
Points: 2,325, Level: 29 Points: 2,325, Level: 29 Points: 2,325, Level: 29
Level Up 17% Completed
FF Reputation: 0 smallblockfever Newbie
Has anyone had luck relocating the 02 sensor bung on either the header or the cat? I'm going to replace them because I snapped them both. I figure that if I can eliminate the problem from the get go then why not?
I can take care of the header easily, but the cat is tricky. Has anyone had luck with plugging the stock bung with a plug and re-welding a new bung in a less interference-prone area?
I'm nervous about bringing a welder anywhere near an SVT cat... Guidance and suggestions are greatly appreciated.
smallblockfever is online now
Old 03-25-2013, 10:27 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (11)
I know some have moved them on the ORP's due to them getting broken, I don't see why it couldn't be done on the cat.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 03-26-2013, 12:22 AM   #3
marcanjelo7
marcanjelo7's Avatar
Fan#: 65638
What I Drive: 2001 Blue SE
Points 442, Level 8
Points: 442, Level: 8 Points: 442, Level: 8 Points: 442, Level: 8
Level Up 84% Completed
FF Reputation: 1 marcanjelo7 Good Standing Member
it's possible. the one I bought from a member had their rear o2 relocated to the side.
01 FOCUSED!
marcanjelo7 is offline
Old 03-26-2013, 03:12 AM   #4
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,273, Level 35
Points: 3,273, Level: 35 Points: 3,273, Level: 35 Points: 3,273, Level: 35
Level Up 49% Completed
FF Reputation: 3 paulg127 Good Standing Member
Be sure to adhere to the usual tip-down, 10-15 degrees minimum from horizontal.
paulg127 is offline
Old 03-31-2013, 09:04 PM   #5
smallblockfever
Fan#: 95004
so it has to stay 10-15 degrees above horizontal?
is there no issue with the catalyst being messed up by rewelding a new bung elsewhere? The heat from the weld won't alter the catalyst?
Old 04-29-2013, 08:24 PM   #6
smallblockfever
Fan#: 95004
PROBLEM SOLVED
HUGEEEEEEEEEEEEEEEEE thanks to Tom for the info, advice, and know-how he provided to me. 'Twas invaluable.
What I ended up doing was relocating the bungs. I relocated a bung onto the side of my header right when pipes converged into one, right before the flange to the cat. The sensor is now mounted approximately 5-10 degrees above horizontal and is totally clear of any possible complications with the oil pan. As for the rear sensor, it seems that my wires were only stretched and not actually broken, so I straightened the sensor and plugged everything up. Couple of days later the CEL went away!!
Now I had bought a spare cat to replace the one on the car (one on the car is cracked). I welded bungs to the new-to-me cat to fix the rear problem as well by grinding down the lip near the rear OEM location and welding a bung in similar fashion with my new front mount.
Only problem I have now is I cannot for the life of my get the old cat off... Bolts are fully rusted, and the bracket holding the cat to the car is snapped in half so the entire exhaust moves around when I try wrenching on it.
If anyone has any tips on that, let me know. Otherwise it is gonna stay on the car until it becomes absolutely necessary to remove the cat.
Old 04-30-2013, 02:39 AM   #7
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,554, Level 100
Points: 52,554, Level: 100 Points: 52,554, Level: 100 Points: 52,554, Level: 100
Forum Activity 54%
Buy-Sell-Trade Rating: (28)
You will have to just strip/brake the bolts off , its very common , then drill and use bolts and nuts
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 05-16-2013, 02:37 AM   #8
s0B0Ta
s0B0Ta's Avatar
Fan#: 109940
What I Drive: 02 Silver SVT
FF Reputation: 1 s0B0Ta Good Standing Member
I took my cat pipe off the car, took a grinder, opened it up like a sardine can, took the metal honey comb out and the ceramic top one out too, welded it back up, called Tom and made it into an Off Road Pipe.
But then again, i do live in a county where emissions testing is not mandatory :D
Thanks Tom!
s0B0Ta is offline
