car wont start - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-25-2013, 06:31 AM   #21
cpalz
Fan#: 105682
What I Drive: 2002 Zx5 Focus, 2005 Zx4 Focus
FF Reputation: 1 cpalz Good Standing Member
Check your fan relay under the hood. It might have suffered as well. It is easiest to swap it out with a relay that is the same design under the hood that is working. Example: If it is the same as the horn relay, and your horn works, switch the fan and horn relay. See if both work.
cpalz is offline
Old 04-25-2013, 09:21 AM   #22
Elder
Points 12,743, Level 73
Points: 12,743, Level: 73 Points: 12,743, Level: 73 Points: 12,743, Level: 73
Level Up 74% Completed
Looks like the Alt. got "fried" as well.
Look for a local rebuilder to fix the one you have, it'll be a lot cheaper & is more likely to work than the "crapshoot" rebuilts we keep hearing about (tried three, finally got one that works, is a typical comment)
Don't run it too long at that voltage, it'll start boiling the battery dry quite quickly...
Luck!
sailor is offline
Old 04-25-2013, 05:10 PM   #23
Luis360
Luis360's Avatar
Fan#: 35708
What I Drive: 2002 Black ZX3
Points 1,781, Level 24
Points: 1,781, Level: 24 Points: 1,781, Level: 24 Points: 1,781, Level: 24
Level Up 81% Completed
FF Reputation: 1 Luis360 Good Standing Member
im going to keep my car parked at home till everything is working properly. dont want to overheat my car. im going to replace the alternator. i changed the relays today and still doing the same thing. fans wont turn on even if i turn my a/c on.
Luis360 is offline
Old 04-25-2013, 05:12 PM   #24
Luis360
Luis360's Avatar
Fan#: 35708
also gonna replace the battery cables. the positive one is messed up anyways
Luis360 is offline
Old 04-25-2013, 05:13 PM   #25
Luis360
Luis360's Avatar
Fan#: 35708
another weird thing i noticed in my car after the incident is that now every time i start the car, my gauges reset and then stop working.
Luis360 is offline
Old 04-27-2013, 12:40 AM   #26
Luis360
Luis360's Avatar
Fan#: 35708
ok the gauges now work because i bought a new alternator. but now my car wont stay on
Luis360 is offline
Old 04-28-2013, 11:36 PM   #27
Luis360
Luis360's Avatar
Fan#: 35708
car is back on the road. thank you guys for all your help
Luis360 is offline
Old 04-29-2013, 03:24 AM   #28
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
Points 625, Level 12
Points: 625, Level: 12 Points: 625, Level: 12 Points: 625, Level: 12
FF Reputation: 3 Kodyston Good Standing Member
Umm... What did you do to fix it so we will know if it happens to us. lol
Kodyston is offline
Old 05-01-2013, 11:48 AM   #29
Luis360
Luis360's Avatar
Fan#: 35708
the alternator failed all the test when i took it to advance auto parts. i replaced the alternator and it fixed everything. the stalling problem i encountered was a vacuum hose that was accidentally disconnected when i was replacing the alternator lol
Luis360 is offline
Old 05-01-2013, 12:29 PM   #30
Kodyston
Kodyston's Avatar
Fan#: 112498
lol Awesome. I'm glad you got it fixed.
Kodyston is offline
