Dumbest Questiont Yet: Jack Stands - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-25-2013, 09:19 PM   #1
dutd33
Fan#: 104381
What I Drive: 2012 White Platinum SEL Hatch
Points 1,977, Level 26
Points: 1,977, Level: 26 Points: 1,977, Level: 26 Points: 1,977, Level: 26
Level Up 77% Completed
FF Reputation: 1 dutd33 Good Standing Member
I know this is probably super stupid, but I'm not that great with cars. If I'm going to jack my Focus up so that I can kick my seized tires, where should I put the jack stands so that it's the safest for me?
Also, would taking a rubbing mallet and hammering away at the tires or using a 2x4 and knocking the rim damanger the rotors or hurt the alignment?
Thanks in advance.
dutd33 is offline
Old 04-25-2013, 09:26 PM   #2
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
Points 8,163, Level 61
Points: 8,163, Level: 61 Points: 8,163, Level: 61 Points: 8,163, Level: 61
Level Up 5% Completed
Forum Activity 9%
What do you mean "seized tires"? You mean the wheels are stick to the hub/rotors?
If so, you can give it a light kick or blow with a mallet without damage, but don't go crazy. It shouldn't need a ton of force to remove anyways.
The closer to the outside corners of the car you get, the more stable it will be. The pinch welds right behind the front wheels and behind the rears are likely your best bet. If you're hammering the wheel hard enough to push it off stands put there you're using way too much force (and/or awful stands). You shouldn't be under the car while applying the force as well, regardless of how stable the stands are.
Hatch Nation #29
Joeywhat is online now
Old 04-25-2013, 09:38 PM   #3
dbenney
Fan#: 1195
Points 968, Level 16
Points: 968, Level: 16 Points: 968, Level: 16 Points: 968, Level: 16
Level Up 68% Completed
I would not use the flange where the rocker and underbody meet. Thats fine to jack it up by, but for jackstand placement i prefer to place my stand under the control arm rear eye. it is very stable there. just remember lign up your stand, lower the car onto the stand and as soon as it touches leave the jack right there.
dbenney is offline
Old 04-25-2013, 09:47 PM   #4
dutd33
Fan#: 104381
Yeah, the winter tires I have on are seized to the hub. I'm going to try to spray some liquid wrench or PB Blaster and free it up a bit and then hammer away.
Thanks!
dutd33 is offline
Old 04-25-2013, 09:47 PM   #5
dutd33
Fan#: 104381
Great tip. I'm sooo stupid so please forgive me. Whereabouts is the control arm rear eye?
Thanks.
dutd33 is offline
Old 04-25-2013, 09:59 PM   #6
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,768, Level 54
Points: 6,768, Level: 54 Points: 6,768, Level: 54 Points: 6,768, Level: 54
Level Up 9% Completed
FF Reputation: 9 SilverPony2001 Good Standing Member
Twice while doing my brakes on my 02 ZX5 the tires would not come off no matter how hard I kicked or banged with a mallet. I just left the lugs off, and lowered the jack so the car was back on the ground, and that broke it loose. Didn't have to drive or anything. Maybe you could try that.
SilverPony2001 is online now
Old 04-25-2013, 10:23 PM   #7
sprof
sprof's Avatar
Fan#: 113150
What I Drive: 2013 Focus SE
Points 187, Level 3
Points: 187, Level: 3 Points: 187, Level: 3 Points: 187, Level: 3
Level Up 74% Completed
FF Reputation: 1 sprof Good Standing Member
Thanks for being smart enough to use jack stands. :beer:
Sent from my HTC One X
2013 Ruby Red Focus SE sedan
Built on 3/7/13
Fuelly log -- http://www.fuelly.com/driver/sprof/focus
sprof is offline
Old 04-25-2013, 11:07 PM   #8
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
FF Reputation: 3 Juicedz Good Standing Member
No stupid questions.....unless its already been asked....;-). Serious though, don't be afraid to ask. It's a big forum and there's tons of us to respond.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 04-26-2013, 08:21 AM   #9
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,898, Level 59
Points: 7,898, Level: 59 Points: 7,898, Level: 59 Points: 7,898, Level: 59
Forum Activity 40%
Buy-Sell-Trade Rating: (15)
Also, remember to do this on a flat surface and to chock the opposite tires. Can never be too safe...
Careful with the pb blaster, try not to get any on the rotor/pads. When you put the wheels back on, you can put a little bit on the back of the wheel where it meets the hub...should help next time you have to take the wheels off.
rambleon84 is online now
Old 04-26-2013, 08:49 AM   #10
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,154, Level 74
Points: 13,154, Level: 74 Points: 13,154, Level: 74 Points: 13,154, Level: 74
Level Up 76% Completed
Forum Activity 37%
Buy-Sell-Trade Rating: (46)
After you get those wheels off I would suggest using anti-seize in the future to prevent this from happening. Just a thin layer goes a long way in keeping your aluminum wheels from sticking to the cast iron hubs.
As for the jack stands, this is always a good reference. I know it is for the older models but it still applies to the newer ones as well.
Personally, I wouldn't trust the jack-stands under the pinch welds but that's just me. I know people have used them in the past without any problems.
zetecDon is online now
