Rally Racer needs 2.3L / 2.5L Help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-23-2013, 08:04 PM   #1
MainiaxMotorsports
Fan#: 84528
What I Drive: 2002 Rally-Spec SVT w/ 2.5L swap
Points 1,049, Level 17
Points: 1,049, Level: 17 Points: 1,049, Level: 17 Points: 1,049, Level: 17
Level Up 49% Completed
FF Reputation: 2 MainiaxMotorsports Good Standing Member
Hey crew - i dont post that often but this one is a bit challenging, and thought you ninjas here would know the answer. I ran the Empire State Performance Rally this weekend in Monticello - and while my other two team members both have boost on thier Foci - i want to stay all motor - the car ran great, decent stage times - one huge penalty for a broken shift linkage/being late to stage, but i want a bit more power....how much more......well......
I run a 2002 SVT with a 2004 2.3L Duratec and MTX75 in my Rally Car
I have a custom built wire harness with circuit breakers to make tracing electric issues a ton easier....spent like $4k having it wired up
Now, i want to drop in a 2.5L i4 for a number of reasons......however
WILL THE 2.3L TOP END mate up with a 2.5L bottom end???????
What will i loose in power / tq with this config?
What are the GOTCHAS waiting for me?
I will take any and all advice, suggestions, or dude, you are NUTS comments ;)
[IMG][/IMG]
MainiaxMotorsports is offline
Old 04-23-2013, 08:46 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,387, Level 100
Points: 51,387, Level: 100 Points: 51,387, Level: 100 Points: 51,387, Level: 100
Forum Activity 25%
Buy-Sell-Trade Rating: (28)
Hmmmm ... where have I seen that car before ??? LOL
Use the 2.5 head , I can send you some "In the works" 2.5 Dynos
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-23-2013, 08:59 PM   #3
MainiaxMotorsports
Fan#: 84528
Found the ScT in the glove compartment - still running your tune
if i use the 2.5 head - new ECU, Instrument cluster needed??
Old 04-23-2013, 10:00 PM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 25%
Wouldnt need a new ECU or instrument cluster to run the 2.5 head
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-24-2013, 08:18 AM   #5
teamDFL
teamDFL's Avatar
Fan#: 92060
I believe that all the 2.5s have VCT which I don't think the Focus ECU can handle. Maybe Tom has either a mechanical or tuning solution for that, but when I researched this swap 10 months ago, there was no readily available solution to that problem.
Rally Revolution #21
teamDFL is offline
Old 04-24-2013, 09:46 AM   #6
Fernando_221
Fan#: 79468
What I Drive: '06 ZX4 2.0L Dtec, '11 MK2.5 2.0L
Points 1,785, Level 24
Points: 1,785, Level: 24 Points: 1,785, Level: 24 Points: 1,785, Level: 24
Level Up 85% Completed
FF Reputation: 3 Fernando_221 Good Standing Member
My friend and me did a swap from duratec 2.0 to duratec 2.5.
The stock 2.0 doesn't have VCT and the 2.5 has VCT. All we need to do was leave the VCT solenoid unplugged and the engine is running perfectly.
I did some tests with the VCT solenoid and it works with a 12v input. If you send 12v to the solenoid, it opens and leaves the oil to flow to the variable cam gear.
The car has a LOT of torque. The engine is entire stock, cams, header, intake all stock, it revs good up to 6k rpm. I'm wondering this thing with a Cosworth IM, FS/OBX header and a set of Crane 2...
Fernando_221 is offline
Old 04-24-2013, 11:19 AM   #7
MainiaxMotorsports
Fan#: 84528
This is VERY helpful
seems like the only two things that need to be focused on are
1. the VCT / both the oil chase and the solenoid (do you unplug solenoid / block oil chace) or let her flow and unplug solenoid, or just run vct manually?
2. Bell housing - everything i read - if that bell housing / starter position match up = mtx75 and all the goodies there are good to go
I am going to pull the trigger and get the motor in, and will kick off a
FOCUS 2.3L to 2.5L SWAP THREAD from square one on...
Old 04-24-2013, 12:10 PM   #8
teamDFL
teamDFL's Avatar
Fan#: 92060
If all you need is 12v to trigger the VCT, then just get yourself a relay and an RPM switch. That way you can activate it whenever you want.
Excited to see this move forward. I think the 2.5 will be a good swap for years to come. Bigger is better.
teamDFL is offline
Old 04-24-2013, 12:30 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 25%
Actually the VCT doesnt work off 12 volts and never hits 12 volts it like most VCT works off of variable voltage off load vs RPM
If this isnt hooked up properly or a VCT Elim then he is loosing some TQ and HP
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-24-2013, 12:35 PM   #10
MainiaxMotorsports
Fan#: 84528
OK - going for it !!!!!
Ok, thanks to the ninjas on this forum - i am going for it. Here is what we are doing.
1. I have a 2002 Focus SVT Rally car - that started life as a production class vehicle in Rally America, USRC, and NASA
2. We then did a Zetec (out) for a 2.3L Duratec (IN) swap - the car is now Open 2wd Heavy and Group 2 depending on the sanctioning body. Runs the MTX75 Tranny. She runs great, is "competitive", but is not fast and requires a LOT of rev management to stay in the power band, and torque is really not there to dig out of corners on either tarmac, track, or gravel (insert also ice/now) stages.
3. I just bought a 2.5L Duratec i4 out of a 2010 Ford Fusion !!!!!
Let the Build begin......will be documenting each step on this thread for others to follow - including all HIGH FIVES, and OH SHIT moments....enjoy.
The Car with 2.3L Duratec
The Engine Bay with current 2.3L Duratec Setup
The Bell Housing w MTX75
[pic pending]
The Dash Cluster w Custom Wire Harness Circuit Breakers
The Car on Stage moving right along ;)
NEXT POST:
The new (pulled) 2.5L I4 Duratec from a 2010 Fusion Arrives
[pic]
