Not your average Turbo Build - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-22-2013, 06:23 PM   #61
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
What I Drive: 2005 Grey ZX4
Points 1,218, Level 19
Points: 1,218, Level: 19 Points: 1,218, Level: 19 Points: 1,218, Level: 19
Level Up 18% Completed
FF Reputation: 8 AMMO-Duke Good Standing Member
UPDATE!
If you remember, my turbo oil drain goes directly into a hole in the side of the head that had a large plug from the factory. Of course they could not use something with a common thread size, they just had to come up with some oddball size that you cannot find hardware for. It is a 3/4 inch thread but the threadcount is very fine. So what I did originally is just stick the hose in the hole(it fit tightly). I know this is not very scientific, but it never leaked a drop. The real issue was that the hose was not made for oil and I knew that I would have to deal with it sooner or later. Well...the hose got really soft, so I decided to fix it more permanently.
I used a 3/4 garden hose adapter as seen in the pic below. I added a large o-ring that fits perfectly inside the smooth part of the hole before the threads.
I added a good amount of RTV to the threads and cross-threaded that sucker in. It is very tight and is not going anywhere!
Here is a pic of the oil drain on the bottom of the turbo.
I used an oil rated hose(same as I use on my oil cooler). There is no clamp on the adapter side because the hose is so tight that I could barely get it on to begin with.
Finished....no leaks and no oil drain issues!
AMMO-Duke is offline
Old 04-22-2013, 06:55 PM   #62
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
Its just my opinion here but that doesnt look like a very good idea for a turbo drain , there is no flow for it
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-22-2013, 07:12 PM   #63
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Tom
Agreed. Should never have a hard 90 off the turbo.
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 04-22-2013, 09:44 PM   #64
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
I agree also. But I believe this was my best option with the turbo in this location. It is hard to tell by the pic, but the turbo is tilted slightly so the bottom of the 90 is not level, giving it a little elevation. Plus, there is no standing oil inside the head in this area, just open space. This all adds up to it working just fine so far.
Old 04-23-2013, 12:22 AM   #65
Roushturboedzx3
I Fab Too Much
Fan#: 42814
NO the 90 does not add up to it working fine. Need to put a normal flange and run a line all the way down like they (I) do on the K-series sidewinder manifolds. there no point to mess the seals up on the turbo for a 30.00 fix.
Old 04-23-2013, 02:42 AM   #66
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
props for the build AMMO-duke it looks badass :)
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 04-23-2013, 08:21 PM   #67
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Thanks! I am having a ton of fun with it.
Old 04-23-2013, 08:29 PM   #68
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Dyno results:
Stock Duratec 2.0
Stock Intake Manifold
Ancient T-4 turbo
93 Octane
10.9 AFR
10.5 PSI
Question, why is my power curve so jagged? Only thing I can think of is I had the spark plug gap at .045. I was experimenting with different gaps and could not tell a difference until on the dyno. I now have the gap at .035, but I regret not figuring this out before the dyno. I hope I did not lose power because of this, It will irritate me to know if I could have made more power. Any other ideas???
Daryl
Old 04-23-2013, 08:41 PM   #69
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
Got a datalog and I will help you with the top end rough lines , looks like timing
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-23-2013, 11:23 PM   #70
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Thanks! I will get a fresh datalog in the next couple of days. Unfortunately, I did not datalog the dyno runs because I was helping a friend learn how to operate the dyno for the first time at the shop where he works.
