Slapping/ticking sound from engine. - Ford Focus Forum, Ford Focus ST Forum
Old 04-21-2013, 05:36 PM   #1
vaszya
vaszya's Avatar
Fan#: 94970
What I Drive: 2001 Silver ZX3
Points 108, Level 2
Points: 108, Level: 2 Points: 108, Level: 2 Points: 108, Level: 2
Level Up 16% Completed
FF Reputation: 1 vaszya Good Standing Member
Hi,
I'm having a ticking sound, rather it's more like a slapping sound like you would get from a playing card slapping against a bicycle spoke. Noise increases in speed with rpm increase.
It's coming from the drive-belt area but I cannot pinpoint it further.
Is there anything that is known for making this type of sound? Belt tension is to spec and doesn't appear visibly worn.
Thanks in advance!
(Zetec engine, year 2001)
vaszya is offline
Old 04-21-2013, 05:38 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,059, Level 85
Points: 18,059, Level: 85 Points: 18,059, Level: 85 Points: 18,059, Level: 85
Level Up 42% Completed
Forum Activity 28%
FF Reputation: 48 iminhell Great Standing Member
Timing belt may be torn and that loose part is flapping in the breeze.
Best not drive it until you inspect the belt.
iminhell is offline
Old 04-22-2013, 12:40 AM   #3
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,050, Level 55
Points: 7,050, Level: 55 Points: 7,050, Level: 55 Points: 7,050, Level: 55
FF Reputation: 4 matmatician Good Standing Member
It may be your intake manifold if they have the same issue that the 2.0 duratec has. They have little runner flaps (kinda like the butterfly valves on a carbeuretor) and those tend to wear out between 80-100k miles. If thats the root of the problem, dont worry about it. Like I said though, i'm not sure that a problem on the Zetecs, it may only be for the Duratecs.
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 04-22-2013, 01:21 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 10,465, Level 68
Points: 10,465, Level: 68 Points: 10,465, Level: 68 Points: 10,465, Level: 68
Level Up 4% Completed
FF Reputation: 59 felixthecat Excellent Standing Member
D-tech's only, Pancake man !!!!!!
felixthecat is offline
Old 04-22-2013, 01:57 PM   #5
vaszya
vaszya's Avatar
Fan#: 94970
Points 108, Level 2
Thanks for the replies.
I took off the upper timing belt cover and the belt isn't in bad shape.
It seems I'll live with it until it gets worse.
Thanks guys!
vaszya is offline
Old 04-22-2013, 02:38 PM   #6
felixthecat
w/ my magic bag
Fan#: 80663
Thanks guys!
You looked at the rest of the belt? How long has it been on? Records?
Old 04-22-2013, 02:45 PM   #7
joecicalese
Fan#: 105573
What I Drive: 2001 Black ZTS
Points 1,175, Level 18
Points: 1,175, Level: 18 Points: 1,175, Level: 18 Points: 1,175, Level: 18
Level Up 75% Completed
FF Reputation: 4 joecicalese Good Standing Member
guck guck guck noise
My girlfriend's SPI made a noise similar to what you describe until I replaced the serp, idler, tensioner, timing belt, and water pump. I think it was the water pump pulley. If this is the case, now's your chance to install UDP!
joecicalese is offline
Old 04-22-2013, 02:51 PM   #8
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 855, Level 15
Points: 855, Level: 15 Points: 855, Level: 15 Points: 855, Level: 15
Level Up 55% Completed
Forum Activity 9%
FF Reputation: 3 CotyM Good Standing Member
I would check the water pump... Mine was making a rather interesting sound like that, turned out that one of the bolts on the pump pulley had worked it's self lose somehow... I imagine it was because I put to much anti-seize on it... Could be the water pump all together, I believe they are prone to failure on these cars???
Hatch Nation #32
I'm mad! Your mad! We're all mad here!
CotyM is online now
Old 04-22-2013, 02:59 PM   #9
joecicalese
Fan#: 105573
BTW, if you change the thread title to "Slapping/tickling" you're bound to get more hits.
Old 04-22-2013, 03:47 PM   #10
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,567, Level 22
Points: 1,567, Level: 22 Points: 1,567, Level: 22 Points: 1,567, Level: 22
Level Up 67% Completed
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
That noise in the I'M happens in the Zetec also. Had me going crazy for ever until I figured out it wasn't the engine making the noise. It's also happening to my other one now an its at 160k
anarchy0392 is offline
