'05 audiophile subwoofer wiring harness - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-08-2013, 03:20 PM   #1
lap561
Fan#: 112281
What I Drive: 2005 Gray ZX4 ST
FF Reputation: 1 lap561 Good Standing Member
Originally when I bought my car, it came with the OEM sub and amp combo but the HU didn't have the output for the sub wiring harness. I found another HU online with the output and swapped it out. I'm still not getting anything out of the sub and now I'm wondering if I even have the right wiring harness.
Here's what mine look like:
in-dash harness:
Color from left to right:
red/white
green/yellow
black/gray
black/white
Trunk harness:
Can anyone tell me what's wrong and why no sound is coming out of the sub?
lap561 is offline
Old 04-08-2013, 07:15 PM   #2
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
Did you check the sub fuse? Also make sure both plugs are hooked up, the one under the dash is the sub out put that goes into the back of the HU, its identical to the one I had in my 07 F150 w/audiophile.
Stick a paper clip between the blk/gray and blk/white on the in dash harness and stick an ohm meter on pins 3 and 4 on the trunk plug and you should have continuity. Also plug in the dash plug to HU and you should get +5v at pin 10, that is the remote signal. If all this checks out and the fuse is good, then most likely the audiophile amp is blown.
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 04-08-2013, 07:21 PM   #3
I Bleed Ford Blue
Fan#: 94113
in-dash harness:
red/white___remote
green/yellow___shield and/or ground
black/gray___sub input -
black/white___sub input +
I added what each wire on the in dash plug should be.
L-CCC #18/HOIA #37
Old 04-08-2013, 11:52 PM   #4
lap561
Fan#: 112281
Yes. The 30A fuse on #F24 is good. What do you mean that both plugs are hooked up? I just unplugged them to take pics.
Sorry for the dumb multitester question but when I test pin 10, do I put the other one on ground I assume?
Aside from getting another stock amp, what amp options are there available?
lap561 is offline
Old 04-08-2013, 11:54 PM   #5
lap561
Fan#: 112281
Thanks!
lap561 is offline
Old 04-09-2013, 04:48 AM   #6
I Bleed Ford Blue
Fan#: 94113
Yes after you test everything, hook them back up and see if the sub now works.
Yes the other lead from the meter goes to ground. Also check pins 4 and 5 and make sure you have 12v there.
Anything you want. If the amp power requirements are 30A or less you can use the factory power leads. And the remote signal may have to be stepped up to 12v for an aftermarket amp. You can do this by running it thru a relay, by putting the 5v to the coil of the relay. Run pins 3 and 4 to a male RCA plug with pin 4 to the center of plug.
L-CCC #18/HOIA #37
Old 04-20-2013, 05:49 PM   #7
lap561
Fan#: 112281
Thanks to 'I Bleed Ford Blue' for helping me out. It turns out that the ground on the wiring harness was the problem. I was getting +12v when testing the red wires (pins 5 and 6) against the chassis but not the blue/black wires (pins 8 and 9). So I cut those two wires and rigged it to one of the bolts at the bottom where the sub mounts on to. I had to use some speaker wires to make it long enough to reach.
lap561 is offline
