Removing Door Panel - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-08-2008, 09:59 AM   #1
Zheka
Zheka's Avatar
Fan#: 40598
What I Drive: 2001 Silver ZX3
FF Reputation: 6 Zheka Good Standing Member
Exclamation Removing Door Panel
I cant seem to find a way on how to remove my door panel. Why? So I can replace my speakers.
Zheka is offline
Old 05-08-2008, 10:08 AM   #2
CKA
Fan#: 2313
What I Drive: '02 ZTS/'99 Explorer/'13 Fusion
FF Reputation: 74 CKA Excellent Standing Member
Buy-Sell-Trade Rating: (24)
Moved you to interior chat.
But there are these little screws at the bottom and sides you need to remove.
Also another one hidden behind the door handle and with a small flat head remove the banana looking piece which is located under the door handle.
Sorry my explanation is bad. I am better at just doing it.
Then after all that, pull up the hole piece and it comes off.
CKA is offline
Old 05-08-2008, 10:41 AM   #3
Zheka
Zheka's Avatar
Fan#: 40598
sorry for posting in the wrong place, didn't think about it....
is it easy to put it back?
Zheka is offline
Old 05-08-2008, 10:49 AM   #4
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
ive had my doors off probly 50 times or more now....
first look behind the door handle, you will see a little disk about 1/2 inch diameter. Pry that out with a tiny flathead screwdriver
take out the screw behind there with a T15 torx
then go around the door and take out all the T15 torx screws, theres 8 i think
then look underneath the handle where you grab to close the door, you will see a small square hole. put your tiny flathead up there and pry outward, eventually you will get it just right and the insert will pop out.
get an extension and a 1/4" deep socket on your 1/4" drive ratchet and take out the 2 bolts under that insert
now put the window down (it is MUCH easier both on and off with the window down)
now you can pull out a little and lift on the door panel, it will get caught on the door handle but im sure you could work that out. Also use your tiny flathead to help you unclip the harnesses from the lock and window switches
install is the reverse. start by laying the rubber strip along the top of the door while holding the panel at an angle, like 15 degrees, then swing it down and start putting screws in
SUV this!
illinipo is offline
Old 05-08-2008, 11:24 AM   #5
Roland07
Roland07's Avatar
Fan#: 51147
What I Drive: 2007 Pitch Black ZX3
Points 5,670, Level 48
Points: 5,670, Level: 48 Points: 5,670, Level: 48 Points: 5,670, Level: 48
Level Up 60% Completed
FF Reputation: 51 Roland07 Excellent Standing Member
The plastic insert around your door handle is just held onto the rest of the panel with clips. You can pull it off, and easily around the door handle, by tugging it straight off the panel. Makes taking the whole panel off and replacing it WAY easier, with less chance of messing up your handle.
Goal: To have as much fun building the car as I do driving it.
Phase: Drivetrain
L.O.T.H. #9
Roland07 is offline
Old 05-08-2008, 07:39 PM   #6
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
Post
I thought I would offer this. These are the instructions that I got with my aftermarket speakers. I blotted out the merchant's logo, so I hope I'm still within FF rules and regs. I hope this helps you and any other FF out there. Just remember to roll your windows down before you start so you won't have to worry about doing it later in mid-removal.
The only special tool you will need is a door panel remover tool. Good luck and be careful not to break anything.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
Last edited by CJohn364; 05-16-2008 at 06:10 PM. Reason: I didn't realize I forgot the first page, sorry.
CJohn364 is offline
Old 05-16-2008, 05:42 PM   #7
marcushe
Fan#: 52508
What I Drive: 2008 SES
FF Reputation: 1 marcushe Good Standing Member
Great pics you provided to help him out.
Do you have any documents like that for the 2008? I want to replace my speakers as well.
Thanks!
marcushe is offline
Old 05-16-2008, 05:51 PM   #8
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Thanks!
Sorry, I sure don't. I just kept those from the aftermarket head unit I bought. I hope the 04- models are not much different than the 05-07 models. These instructions were for my 05. I still hope someone gets use out of them.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 08-23-2009, 11:05 AM   #9
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
*NOTE*
I organized my Photobucket and ended up moving these pics, but here they are again.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 04-13-2013, 09:31 PM   #10
KyleKaplan
Fan#: 83998
What I Drive: 2011 Blue SES
FF Reputation: 1 KyleKaplan Good Standing Member
Shouldn't this post be in the MKI section of the forums, rather than the MKII?
KyleKaplan is offline
Similar Threads
[How To] Removing a broken bolt. Algorhythm General Technical Chat 6 07-31-2013 06:40 PM
Removing the Exhaust Resonator? redsvtf SVT Performance (2002-2004) 13 04-01-2007 10:44 PM
Removing air-box resonator? slipster17 ZETEC Performance (2000-2004) 8 12-07-2006 11:41 AM
Removing the Cat andyzzdae38 ZETEC Performance (2000-2004) 19 10-28-2006 11:45 PM
Write-up: How to determine approx. HP gains from removing weight! Taiden Ford Focus & General Car Chat 47 12-07-2005 09:33 AM
