Cam Install Guide and the timing chain... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-30-2013, 06:16 PM   #1
SMITHBOY76908
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
Points 14,482, Level 78
Points: 14,482, Level: 78 Points: 14,482, Level: 78 Points: 14,482, Level: 78
Level Up 8% Completed
FF Reputation: 18 SMITHBOY76908 Great Standing Member
I've been going by the following cam install guide to get my cams in but I have a feeling it's inaccurate.
http://duratec.wikispaces.com/modification-cams
I did exactly as it says with putting the bolts in the crank pulley and the timing cover to lock the chain guide in place but when I removed the exhaust cam gear, the guide snapped out of place and the timing chain came off the crank gear. :mad: I don't think that 20mm bolt worked like it was supposed to work...
Is there a way to release the tension on that guide and get the chain back on the crank gear WITHOUT having to remove the timing cover? I really don't want to have to go through all that but I will if I have to. Any ideas?
Russia... is... awesome!
SMITHBOY76908 is offline
Old 03-30-2013, 09:44 PM   #2
PSUrivie
PSUrivie's Avatar
Fan#: 67329
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
Buy-Sell-Trade Rating: (10)
Hey Bryce, there is a hole in the timing cover that gives you access to release the tension. You need to use a small pick or even a paper clip. Its in the shop manual. I'll have to look it up for you.
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 03-30-2013, 10:27 PM   #3
SMITHBOY76908
Fan#: 56301
It's a torx headed bolt, right? Right under the idler pulley. I'm comparing to the timing cover off the built motor on the stand.
I may try that first and see if it works. If it doesn't, I'll pull the cover.
Old 03-31-2013, 09:07 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,926, Level 74
Points: 12,926, Level: 74 Points: 12,926, Level: 74 Points: 12,926, Level: 74
Level Up 19% Completed
I forgot 'bout the tensioner & wham, the tensioner snapped out of place. I endup pulling the cover off= 2 additional hrs. To pull the p/s pump you'll need to remove the hi pressure line.
felixthecat is online now
Old 04-02-2013, 03:00 PM   #5
JSV578
Fan#: 93418
What I Drive: 2008, Black, B23T
Points 69, Level 1
Points: 69, Level: 1 Points: 69, Level: 1 Points: 69, Level: 1
Level Up 38% Completed
FF Reputation: 3 JSV578 Good Standing Member
the tensioner have a spring load and oil pressure load, so it is normal you have this problem.
just hope you to not have the problem me and Felix had... when it completely come off the tensioner.
if not, yes the hex bolt near the fan pulley his the one your looking at.here some photo for ref.
you can see the tensioner location on this one
with the tensioner in place (the release hole is the one closer to the chain
with the cover for ref to and you can see the bolt on this one
ps, I know you cover doesn't look like mine :)
and the special tool I made lol, a M6 bolt split in half that slide perfectly in the release hole of the tensioner and let you release it with a 90 turn.
good luck
JSV578 is offline
Old 04-02-2013, 03:41 PM   #6
felixthecat
w/ my magic bag
Fan#: 80663
Great pix JSV578, in a Ranger. What cams did you install?
Old 04-03-2013, 12:49 PM   #7
SMITHBOY76908
Fan#: 56301
Thanks for the pics. That does help for sure. I'm really hoping it hasn't come off the guide. My cam gears are about an inch short of slack to slide onto the cams and I can free spin the chain so it's not catching on the crank gear.
Custom grinds.
Old 04-03-2013, 01:25 PM   #8
JSV578
Fan#: 93418
Points 69, Level 1
Originally Posted by SMITHBOY76908 View Post
Custom grinds.
nop, the Ranger Duratec share the same 1 lobe cam as the first gen and share the timing gear of the 2.0
so it could be any cams you can find for your engine... but it is still the stock one in the pix
JSV578 is offline
Old 04-04-2013, 03:01 AM   #9
SMITHBOY76908
Fan#: 56301
Sorry, I thought he was asking what cams I was installing. My bad.
Yeah, same thing. It's all a Duratec.
