Stroker Crank / Kit Co-Op? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-19-2013, 03:24 PM   #21
DarwinSays
DarwinSays's Avatar
Fan#: 35941
What I Drive: 2004 SVT Silver / EAP / CWP
Points 1,382, Level 20
Points: 1,382, Level: 20 Points: 1,382, Level: 20 Points: 1,382, Level: 20
Level Up 82% Completed
FF Reputation: 2 DarwinSays Good Standing Member
LAST CALL.
If these get ordered, it will be at the end of next week (Mar 29th-ish) unless/until I attempt the co op again at a later date, or someone expresses an interest in picking one of these kits up before this fall/next spring.
User Gallery
#include 'brain.h'
DarwinSays is offline
Old 03-22-2013, 12:02 PM   #22
blanezx3
blanezx3's Avatar
Fan#: 764
What I Drive: 03 twi-blue zx3
Points 2,469, Level 30
Points: 2,469, Level: 30 Points: 2,469, Level: 30 Points: 2,469, Level: 30
Level Up 13% Completed
FF Reputation: 5 blanezx3 Good Standing Member
Buy-Sell-Trade Rating: (10)
What is included in the kit?
performance?
FR stg 2 cams, UR cam gears, FC 65mm TB, ported 2k manifold, 50lb injectors, FC race header, Bosal flex, Borla catback, Zex, Procharger, Xcal2
blanezx3 is online now
Old 03-27-2013, 01:33 PM   #23
DarwinSays
DarwinSays's Avatar
Fan#: 35941
I don't have a specific parts list yet, but here is what I could find, which are the details of the kit from when Tom still openly offered it on his site:
2.3 billet stroker crank
custom Rods
Custom Forged pistons
Rings
New rod and main bearings
Bal Assy
ARP Main studs
This may not be entirely accurate though; similarly, some of the cost of the kit may be for installation labor. I'll talk to Tom and see if I can get him to chime in with a confirmation of this list, or to provide an accurate list of parts.
I need to talk to him anyway to see how using one of these kits would impact the cost of a freshly built motor from him anyway, since obviously some of the parts he would otherwise use won't be going into the motor, etc.
User Gallery
#include 'brain.h'
Old 03-27-2013, 01:46 PM   #24
Rudel
FF's Quadriplegic!
Rudel's Avatar
Fan#: 13465
What I Drive: 2.3 ATX-RSVT
Points 10,049, Level 66
Points: 10,049, Level: 66 Points: 10,049, Level: 66 Points: 10,049, Level: 66
Level Up 99% Completed
FF Reputation: 15 Rudel Great Standing Member
Buy-Sell-Trade Rating: (17)
Since I'm drag racing mine, it wouldn't hurt to have extra parts. Hmmmm
513whp on Race Gas; Tuned by Fernando@RacingPartsSolution.com
Pump gas? Ppffff!
Part III: Install Handicap Driving Controls
Ma Cah: http://imgur.com/a/TuyYL
Rudel is offline
Old 03-29-2013, 02:32 PM   #25
shadowzx3
shadowzx3's Avatar
Fan#: 55333
What I Drive: 2001 Black ZX3
FF Reputation: 1 shadowzx3 Good Standing Member
I would seriously be interested but this will be by july/august, currently building the savings account to put towards parts. I am planning to rebuild the bottom end myself minus the machine work.
shadowzx3 is offline
Old 03-29-2013, 10:12 PM   #26
sdaddy
sdaddy's Avatar
Fan#: 105173
What I Drive: Green 2002 Birkin w/2L Zetec
FF Reputation: 1 sdaddy Good Standing Member
custom Rods
Rings
Bal Assy
ARP Main studs
I'd be interested in this combination.
Would also be best if timing was late summer so work could be done over next winter.
sdaddy is offline
Old 04-02-2013, 12:49 PM   #27
DarwinSays
DarwinSays's Avatar
Fan#: 35941
I need absolute confirmation if any of you intend to purchase one of these kits. I can push the window back a little if you're serious about picking up a kit, but I would really like to have the new motor installed and operating before this summer if at all possible.
User Gallery
#include 'brain.h'
Old 04-02-2013, 08:24 PM   #28
sdaddy
sdaddy's Avatar
Fan#: 105173
Here are the options I'm seeing for bottom end. Do they sound correct??
1) Stock - cost: nothing - advantage: nothing
2) 2.0L parts as noted in post #9 ~$1,800 + assembly - advantage: smoother and spin to about 7,700 RPM (~5% more HP on top with right top end)
3) 2.0L assembled short block with parts from above ~$2,200 - advantage: as above plus "plug and play"
4) 2.3L parts as noted in post #9 plus forged crank ~$3,700 - advantage: same as point 2 but (guessing here) ~10% bump in HP and Torque
5) 2.3L assembled short block ~$4,000(?) - advantage: same as point 4 but "plug and play"
Are people thinking the same? And, to Tom's question, are there three people (me probably being one and DarwinSays being another) that would spring for option 4 or 5??
Weight: 1200 lbs ...and planning to add more lightness.
sdaddy is offline
Old 04-02-2013, 10:05 PM   #29
DarwinSays
DarwinSays's Avatar
Fan#: 35941
Dammit, you had me scratching my head with your reference to post #5...haha.
You meant post #9, I believe.
1) Correct.
2) 7700RPM might be a bit of a stretch, since the performance up that high would depend on cams; even the SVT cams start to taper at ~6500RPM, and tuning can only do so much.
3) More or less; see above.
4) The 2.3L build - assuming the parts listed in post #23, as you more or less described - would be a 15% increase in displacement. If you optimize the ports and cam to make best use of this, I would think you could see most if not all of that 15%. Otherwise I would agree that 10% is a safe estimate.
5) If memory serves, Tom's assembled 2L long block runs in the vicinity of $3600. So if you figure that plus $3700 for the stroker kit, less any redundant parts (pistons, rods, bearings, main studs, etc.)...you could probably figure a ballpark estimate, but I'd prefer to wait til we hear from Tom himself, whom I haven't contacted yet.
Yeah, I've been slacking a little, lol.
It's a bit late for tonight, but I'll try to catch him in the next day or two.
User Gallery
#include 'brain.h'
Old 04-02-2013, 10:10 PM   #30
sdaddy
sdaddy's Avatar
Fan#: 105173
1) Correct.
You're right... sorry. Time to put on my old-folks glasses. Any news on the actual cost of the 2.3 kit, what's included and what's not?
sdaddy is offline
