Where did I go wrong? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-02-2013, 09:28 AM   #11
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Originally Posted by ShoOff View Post
Lets not forget you may have more than one issue here.
^ This.
For a high mileage SPI engined car with an intermittent misfire, I'd put a compression test high up on my list of things to check.
BC_ZX3 is offline
Old 04-02-2013, 02:19 PM   #12
Enstar
Fan#: 112749
What I Drive: 2000 grey focus se
FF Reputation: 1 Enstar Good Standing Member
Originally Posted by amc49 View Post
By successful, just what do you mean? I'm looking for what you perceived as something better there.
No the cat shouldn't do that, if clogged it would run far worse at higher engine speeds and loads. Idle has so little flow through motor not much effect. Of course simply running all the seafoam through there could have wet a plug or something. Anything extra burning can light off a wet cat inside and then it melts, that's no good. Why you never should run car out of fuel nowadays.
Maybe successful wasn't the right term. What I meant to say I always seem to see an improvement. I also didn't run all the seafoam through there.. I used a 1/4 can and put the rest in the tank..So I guess I am surprised at why such a little amount of seafoam would cause these problems. I am just trying to ask what other issues may be causing the misfire...
Enstar is offline
Old 04-02-2013, 02:22 PM   #13
Enstar
Fan#: 112749
Checked vacuum line, don't see a issue with it..
Enstar is offline
