Added 06 ZX4 SES to the stable - Page 2 - Focus Fanatics
Old 03-26-2013, 09:34 AM   #11
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Buy-Sell-Trade Rating: (14)
Yes, cleaning is far easier and doesn't involve you tracking down a replacement. You can also do the spark plugs, gaped to .055 (if not replacing, at least good to inspect them and check their gaps, I'm a fan of Autolight104's.) I'd disconnect your battery while you clean the maf (15min) that way it will re-learn when you fire it back up, just let it idle for a while.
You can also try cleaning your throttle body, they have been known to collect carbon there as well.
rambleon84 is online now
Old 03-26-2013, 08:55 PM   #12
Tacbob
Fan#: 110886
What I Drive: 06 Dark Toreador Red ZX4 SES
FF Reputation: 1 Tacbob Good Standing Member
Will do.
Been reading about the stealth CAI. Does anyone have a how-to link showing one utilizing the existing box? (someone mentioned it but know details on the equip or procedure) I'd like to increase my air intake while keeping splash prevention.
Thx
Tacbob is offline
Old 03-26-2013, 09:14 PM   #13
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
http://www.focusfanatics.com/forum/showthread.php?t=195366
You cant use the existing intake box , which is inside the fender . Get a prefilter cover and youll be fine .
Sent from my LG-LG730
sam fisher is offline
Old 03-27-2013, 04:55 AM   #14
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
FF Reputation: 28 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat" since most of your questions are maintenance related.
zetecDon is offline
Old 04-01-2013, 06:58 AM   #15
Tacbob
Fan#: 110886
Another question:
The window sticker shows a "traction control" option ($115) but the button in the center console near the heated seat buttons does not light up when pressed nor is there a dash light that comes on. Am I missing something?
Tacbob is offline
Old 04-01-2013, 10:37 PM   #16
gondorian
gondorian's Avatar
Fan#: 105695
You have to hold it down.
"If you want to turn off the traction control system be aware that, for safety reasons, the switch must be pressed and held for at least one second before the system is turned off."
gondorian is offline
Old 04-02-2013, 05:55 AM   #17
<-------Why does it say that you own an 03 Blue SE?
What is a stutter anyway? Is the engine shaking? Not starting completely?
IMO: you should go through tune-up procedures. The PCV is not something you change in this car. Yes you can change it, however it can't be reached easily unless the intake manifold is removed. That's why I say- don't bother with it. You can check the PCV vacuum line to see if it is split if you start having problems that might indicate a massive vacuum leak.
1) change spark plugs. Factory equipped with platinum plugs, but those only last about 80k miles. Use anti-seize unless you want to use a heli-coil some day.
2) Change coil boots. These go bad about 80k miles or so, will cause an uneven idle, and loss of mpg. Cost is $5-8 each, and these simply pull off the coils.
3) Fuel filter. Located under the car on the passenger side rear just in front of the fuel tank. It is in the same location as 00-05 Focis, so you can read How-Tos on changing the fuel filter. Remember: do not remove the fuel clips from the fuel line. Press the fuel clip into the line. If you remove the fuel clip from the line, it will be damaged and some dealers will not sell you a replacement clip without selling you a complete fuel line. Then you have to remove the clip from that line- see the problem? One clip will be easy to release, the other will not, look further up that line and you'll see an easy to reach clip about 6" away, remove that clip, small line, filter, and bracket from the car.
4) Clean the MAF. I have yet to work on a vehicle that needed a new MAF for any reason. These are often replaced by dumb people who don't know how to work on cars. It never helps anyone except the parts seller.
5) Air filter: You already know what to do. I rolled the Stealth CAI through 2 100 yr storms. It works. I didn't use a pre-filter. I made my own with polyester panty hose- which is an old dirt bike trick.
6) Clean the TB: Winter will bring you a sticky throttle if you don't.
Old 04-02-2013, 06:51 AM   #18
Tacbob
Fan#: 110886
Cause that was the car we were looking at and almost bought when I first registered for this site. Vehicle changed. Thanks for the heads up.
I meant to say shudder, not shutter. Car seems to vibrate more than it should.
Plugs, coils and FF were changed fairly recently. I will clean the MAF and TB and continue my CAI research.
Thanks for the response.
Tacbob is offline
Old 04-03-2013, 05:30 AM   #19
^^ Change the fuel filter.
The vibrations are due to a bad motor mount, most likely the front engine mount. Check with our vendor Village Ford for a discount. Get the Ford part for the front engine mount, the rest of them you can purchase Anchor mounts from Rock Auto.com- they have the best prices for those.
Polyurethane mounts are also available, but these will cause constant vibration at idle. Some people like it, some people don't. I have them, and I like them, but nobody rides in my car but me 99% of the time.
Old 04-07-2013, 01:49 PM   #20
Tacbob
Fan#: 110886
Here's a pic of the motor mount. Is that a tear in the rubber? Appear to be a typical failed MK1 Duratec motor mount?
http://www.flickr.com/photos/9139346...in/photostream
Tacbob is offline
