Oil Leak: Dealer said Ford stated This is NORMAL - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-28-2013, 12:45 PM   #131
FordService
FordService's Avatar
Points 3,388, Level 36
Level Up 26% Completed
Forum Activity 25%
Originally Posted by kpblasko View Post
...Crystal, if the dealer ends up uncooperative in getting this issue resolved, can I go ahead and shoot you a PM? These problems are totally unacceptable for a 2012 car with only ~20,000 miles that has been utterly babied.
Sure thing, kpblasko. Include your VIN, dealer, mileage, daytime phone number, and full name so I can research your case.
Thanks!
Crystal
FordService is offline
Old 03-28-2013, 01:12 PM   #132
kpblasko
Fan#: 112275
What I Drive: 2012 Candy Blue Focus SEL
FF Reputation: 1 kpblasko Good Standing Member
Thanks!
Crystal
Thanks for the timely reply, Crystal. We got the car back last night after they reprogrammed the TCM. Their paperwork noted that they heard no grinding noises nor experienced any strange behavior from the transmission. They say they found no fluid leak between the engine and bell housing, but I'll have to climb under the car to check that for myself.
Driving the car, I did still notice the characteristic jerkiness/hesitation during some low-speed acceleration and a less pronounced (intermittent) grinding noise during shifting. This is a slight improvement, but due to the intermittent nature of the problem I suppose only a few days' driving will tell if things get better or if the problems resurface.
kpblasko is offline
Old 03-28-2013, 04:40 PM   #133
FordService
Forum Activity 25%
...This is a slight improvement, but due to the intermittent nature of the problem I suppose only a few days' driving will tell if things get better or if the problems resurface.
Circle back with me in a few days, kpblasko. If you want me to step in, I'll be here. :)
Crystal
Old 04-27-2013, 04:31 PM   #134
SWO_Daddy
Fan#: 100869
What I Drive: 2012 Race Red Focus SEL Hatch
FF Reputation: 1 SWO_Daddy Good Standing Member
Originally Posted by SWO_Daddy View Post
Well, I changed my oil last in September at 20k mi and noticed oil weeping from between the crankcase and bell housing. :( Hoping that it was a freak occurrence, I took a picture and then wiped the oil.
The other week, I changed the oil again and the leak is much worse. :(
I am going to be absolutely livid if my dealer gives me the same answer some of you have received.
FordCustomerService, you should have just received a PM from me. Thank you for your assistance in escalating this matter.
Update: I took it to the dealer within a week of posting (got a call from the regional manager the day after I posted here, btw). They agreed that there was a leak, but put a UV dye in my oil to isolate whether it was the oil, or transmission. I drove the car for another 5k and they determined it was the tranny. They performed the TSB (including replacement of the clutches) in about a day.
Assuming this is the end of my problem with this, I'm happy with the resolution. Everyone at Ford from the dealer on up seemed interested in fixing my problem.
SWO_Daddy is offline
Old 04-28-2013, 08:06 AM   #135
Seriously Focused
Seriously Focused's Avatar
Fan#: 101141
What I Drive: 2012 SGM SE Sport 5 Dr
Points 532, Level 10
Points: 532, Level: 10 Points: 532, Level: 10 Points: 532, Level: 10
Level Up 64% Completed
FF Reputation: 1 Seriously Focused Good Standing Member
Originally Posted by Dysan911 View Post
I took my car in because there's oil seeping from between the Engine and The Transmission. Also a very metallic rattle when the car is in 6th gear and low RPM's. Like going up an incline at almost 40mph.
I just got a call and they said the tech couldn't reproduce the noise and the Oil leak is normal. Its not oil she said,. its some sort of factory fluid that they use during assembly and quite normal for it to leak.
I have officially HEARD THEM ALL now!. THank you FORD!.
I told her that It never did that before and she said that the Tech has had quite a few cases where they saw that same leak and contacted Ford and was told that was a Normal condition of this vehicle.
Yes, all leaks and rattles are perfectly normal on the Ford Focus.
Next...............
Seriously Focused is offline
Old 04-28-2013, 11:25 PM   #136
Buggy_Wang
Buggy_Wang's Avatar
Fan#: 112118
What I Drive: 2013 Grey Focus Trend TDCi 2.0
FF Reputation: 1 Buggy_Wang Good Standing Member
Found a camshaft seal leaking example in local forum (1.6 Ti-VCT, Mileage: 10000KM)
Dealer replaced leaking seals and also replaced variable valve timing controller
(Don't know it is just in case or it caused the leaking?)
URL is here , traditional chinese only, but have lots of photos
http://www.mobile01.com/topicdetail....&t=3323778&p=1
Buggy_Wang is offline
Old 04-29-2013, 04:12 PM   #137
Pendarus
Pendarus's Avatar
Fan#: 94411
What I Drive: 2012 Sonic Blue Titanium 5dr
FF Reputation: 2 Pendarus Good Standing Member
Next...............
There is an anti rust coating they use, it is thick sticky and honey colored. If your leak is thin slippery and oil colored, it's oil, take it back and make them look again.
Does anyone have the TSB that describes the difference that they can show to the dealer?
Sonic Blue Titanium 5dr Titanium Handling Package
Ordered: 01/28/12
Vin: 02/20/12
Build Date: 03/06/12
Delivery Date: 03/30/12
Pendarus is offline
Old 04-29-2013, 08:35 PM   #138
unfocused1
Fan#: 95246
What I Drive: 2012 Candy Blue Ford Focus SEL
Points 986, Level 16
Points: 986, Level: 16 Points: 986, Level: 16 Points: 986, Level: 16
Level Up 86% Completed
FF Reputation: 2 unfocused1 Good Standing Member
COOL!
That's one big reason why I've stayed with Ford and won't look back - awesome post-purchase support. (I will never buy another Toyota... their service department was, shall we say, UN-encouraging...)
A fan of Ford, Freedom, Duncan Yo-Yos (but not Duncan Hines confectionary), and Strattera...
unfocused1 is offline
Old 05-20-2013, 07:25 PM   #139
kpblasko
Fan#: 112275
Crystal
Sent you a PM Crystal.
kpblasko is offline
Old 08-03-2013, 08:00 PM   #140
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,360, Level 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
Level Up 40% Completed
Forum Activity 15%
FF Reputation: 6 CunFFS13 Good Standing Member
I never heard an oil leak was normal before!
Shame on you Ford
CunFFS13 is offline
