What have you done to increase MPG? - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-28-2013, 01:27 PM   #81
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
Hehehe not driving your car doesn't raise your mpg as using zero gas and moving zip gives you 0 haha.
Now if your car was was being towed.....
I think this time before I up the tire pressure in both the front and back, I'm going to chalk the tires first. Nothing like ballooing your tires and having rapid tire wear :S You may save mpg but going to pay much much more later for newer tires.
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 03-28-2013, 01:29 PM   #82
Points 10,060, Level 67
Points: 10,060, Level: 67 Points: 10,060, Level: 67 Points: 10,060, Level: 67
Level Up 3% Completed
Forum Activity 22%
The Focus' coefficient of drag is around .27 which is really good, and may be class-leading. Wind can make a big difference, but try driving a Taurus into the same stiff wind and see how it compares.
You're off a touch. Per Moray Callum as reported in car and driver the sedan was 0.297 CD not 0.27. The hatchback is slightly higher though unfortunately they don't say exactly how.
Consider yourself free to ignore the slightly frumpy sedan. “Well, strangely, it’s the sedan that achieves a 0.297 coefficient of drag,” Callum points out, although he counts it as a pyrrhic victory.
http://www.caranddriver.com/reviews/...d-focus-review
The active grille shutter system may lower that by a few clicks, so either to 0.295, or maybe to 0.27 CD with the grille completely closed off.
suss6052 is offline
Old 03-28-2013, 01:30 PM   #83
Roadworthy
Fan#: 109039
I think because of the displacement of weight is much higher in the front of the car, hence a bit of sag look on the front tires compared to the back when both are at 35 psi. So if you increase the front tire pressure to match the friction profile of the rears, wear may better... or at least more even...
Old 03-28-2013, 02:59 PM   #84
JeremiahD
Fan#: 109939
What I Drive: 2013 Tuxedo Black SE 5spd Hatch
FF Reputation: 1 JeremiahD Good Standing Member
Yeah, honestly, I did it mainly to find the psi sweet spot for handling, any mpg gains are just bonus.
As far as ballooning your tires, I doubt 40psi will by much. I have to take a look at mine, but a lot of all-season tires max rating can but up to 40-42psi.
I used to run 42 front and 38 rear on my Jetta without too much added wear. really made it handle balanced. but obviously all tires are different. some are happy at lower pressure (happy as in normal wear) and some at higher.
at any rate I don't intend to keep these factory tires long.
JeremiahD is offline
Old 03-17-2014, 07:21 PM   #85
Doctor_Leaky
Fan#: 125769
What I Drive: 2005, bronze, ZXW
FF Reputation: 1 Doctor_Leaky Good Standing Member
I spoke to a retired Ford mechanic who told me his factory training told them to advise owners to never use premium in a Zetec. FWIW
Doctor_Leaky is offline
Old 03-19-2014, 03:17 PM   #86
raptor1956
Fan#: 97725
Points 4,294, Level 41
Points: 4,294, Level: 41 Points: 4,294, Level: 41 Points: 4,294, Level: 41
Level Up 72% Completed
Not buying it ... High compression engines are going to have more power and be more efficient with higher octane gas. I run only premium in my 2013 Ti HB and my lifetime average is 38.5mpg at over 31K miles.
In Fords own literature they indicate more horse power with premium gas in there performance engines. Top gear did a show on this and verified a power increase using premium for some but not all cars.
An engine with 12:1 compression is going to prefer higher octane gas.
Brian
Sent from my HTC One using FF Mobile
raptor1956 is online now
Old 03-19-2014, 05:43 PM   #87
Doctor_Leaky
Fan#: 125769
Thanks for he response; the retired mechanic told me the 2005 engine in my car was a low compression long-stroke engine with 10:1 or less compression ratio - again, FWIW
Old 03-20-2014, 07:14 AM   #88
Elder
Points 12,818, Level 73
Points: 12,818, Level: 73 Points: 12,818, Level: 73 Points: 12,818, Level: 73
Level Up 92% Completed
Hey Doc - FWIW your engine is a Duratec, not a Zetec. And since you posted in a section for cars '12 and newer with a different engine design.... Just doesn't apply.
'Fraid the variations can get confusing, for our divisions here (just to keep 'em separate) yours would be considered a "Mk1.5", the first variant on the original.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 03-20-2014, 09:15 PM   #89
autoworks842
Fan#: 149594
What I Drive: 2013 FOUCS se 1988 bmw 320i
Points 68, Level 1
Points: 68, Level: 1 Points: 68, Level: 1 Points: 68, Level: 1
Level Up 36% Completed
FF Reputation: 1 autoworks842 Good Standing Member
I was getting 8L per 100klm
took the top off the air box
now its 7.9L per 1ooklm
so far so good.
autoworks842 is offline
Old 03-21-2014, 11:41 AM   #90
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,814, Level 76
Points: 13,814, Level: 76 Points: 13,814, Level: 76 Points: 13,814, Level: 76
Level Up 41% Completed
FF Reputation: 12 NickCornell Great Standing Member
Weld doors shut and sand smooth. Remove springs, remove all interior trim, remove spare tire, add lightweight full body skid plate, place pizza pans over wheel spokes, push car through town.
Mileage for days
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is online now
