What's wrong with my SVT? (Video and pictures inside) - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-19-2013, 03:13 PM   #11
mikealicious
'Merica
mikealicious's Avatar
Fan#: 47077
What I Drive: 2002 Black SVT (gone), 2012 SEL
Points 8,576, Level 62
Points: 8,576, Level: 62 Points: 8,576, Level: 62 Points: 8,576, Level: 62
Level Up 43% Completed
FF Reputation: 8 mikealicious Good Standing Member
Buy-Sell-Trade Rating: (10)
Is this the inner or outter tie rod? Looks like the inner to me.
Visit here to see fast cars and races. ---> YouTube: mikealicious2k5
mikealicious is offline
Old 03-19-2013, 06:08 PM   #12
rent
rent's Avatar
Fan#: 12823
What I Drive: 03' SVTF
Points 669, Level 13
Points: 669, Level: 13 Points: 669, Level: 13 Points: 669, Level: 13
Level Up 38% Completed
FF Reputation: 2 rent Good Standing Member
That's the outer tie rod.
Get Moog parts with grease-able / serviceable joints. Well worth the cash and should last you quite a bit. As far as the job being involved, if you've never touched a suspension component, it can take a little figuring out. You may need to use some heat on the tie rod in order to get the locking nut to release. Also consider soaking them in PB Blaster. Then, you should be able to spin the tie rod itself off of the power steering arm. Make sure you count the turns and try and match it when you install the new ones.
End-links are straight forward - use a wrench to loosen the nut on both ends, remove nut, remove endlink, install new ones.
-James
'03 SVTF *FOR SALE*
'14 FoST Ingot Silver, bone stock...
rent is offline
