zx2 head on a zx3 engine - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2013, 09:19 PM   #11
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,678, Level 86
Points: 18,678, Level: 86 Points: 18,678, Level: 86 Points: 18,678, Level: 86
Level Up 66% Completed
Forum Activity 18%
Originally Posted by Energyblue98 View Post
uhhh zx2 goes to around 7k... definatly not 6250?
but regardless if it revs more or not, you will need to get a vct delete if you want to use a zx2 head, and the vct deletes for the zx2 are hard to find... unless you can figure a way to wire in the use of the vct into your engine.
the vct is variable cam timing and it's on the exhaust cam (unlike the intake cam on the svt engines).
I don't think you're understanding.
HP peak (stock) is around 6,250rpm for both engines.
We know full well how VCT works and what the differences are between the ZX2 and the SVT ... unfortunately the standard Focus zetec does not have VCT, so both cases are irrelevant.
iminhell is offline
Old 02-18-2013, 09:50 PM   #12
Energyblue98
Energyblue98's Avatar
Fan#: 99294
What I Drive: 1998 Turbo ZX2
Points 512, Level 10
Points: 512, Level: 10 Points: 512, Level: 10 Points: 512, Level: 10
Level Up 24% Completed
FF Reputation: 1 Energyblue98 Good Standing Member
Ah I see, misunderstood that you were talking about peak power.
I was just explaining vct to him considering he is new to the forum I figured it might be good context to add.
and If i am understanding correctly, he is questioning if he can put a zx2 head (with VCT) unto a focus engine (without vct), therefore he would have to either get rid of the vct or figure how to wire it in. Am I misunderstanding something else?
Energyblue98 is offline
Old 02-20-2013, 09:58 PM   #13
jonyrocks
jonyrocks's Avatar
Fan#: 97716
What I Drive: 2002 silver focus svt #1021
Points 568, Level 11
Points: 568, Level: 11 Points: 568, Level: 11 Points: 568, Level: 11
Level Up 36% Completed
FF Reputation: 1 jonyrocks Good Standing Member
i dont get why anyone cant see what he wants... he wants higher rpms, since the zx2 and zx3 heads perform the same, if he wants higher rpms, just swap out the valve springs from a zx2 into a zx3, then get a tune to change the rev limiter,
i'm basing my solution on what everyone's said here, im not sure if the zx2 engine does rev higher than a zx3 one, but valve float is solved by better springs at higher rpms...
tom's advice is best if you're aiming for hp.
jonyrocks is offline
Old 02-20-2013, 10:22 PM   #14
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 389, Level 7
Points: 389, Level: 7 Points: 389, Level: 7 Points: 389, Level: 7
Level Up 78% Completed
FF Reputation: 2 150mphzetec Good Standing Member
don't do it. Swapping the head will only net minimum gains if any. The reason the ZX2 drives different is because it is lighter than the focus. Plus the ZX2 had a slightly higher horsepower rating than that of the focus in 2000.
The hassle of swapping the head is not worth it. Just listen to these guys who have been around a while as they have valuable experience behind them.
150mphzetec is offline
Old 02-21-2013, 12:12 AM   #15
Energyblue98
Fan#: 99294
I'm actually looking for a zx3 head to put on my new engine build because it doesnt have vct :)
can you tell that i hate vct?
MFactory LSD, 12.5" Wilwood Brakes, Borg Warner T04b Turbo, Custom Fabricated Manifold, 42# injectors, SVT fuel pump, SCT XCAL2 professional dyno tune, Ground Control coilovers, wings west lip kit, 17x7.5 Volk TE37s
209.3whp / 246.7wtq
Old 03-16-2013, 04:30 PM   #16
Trev FF
Trev FF's Avatar
Fan#: 99052
What I Drive: 2000 focus ZX3 SVT
Points 1,658, Level 23
Points: 1,658, Level: 23 Points: 1,658, Level: 23 Points: 1,658, Level: 23
Level Up 58% Completed
FF Reputation: 1 Trev FF Good Standing Member
my 2000 zx3 redlines at 7
2000 infra-red focus zx3 5 speed
AEM short ram intake, Svt header, CAT, fsWerks flexpipe, custom cat-back, custom red interior, SVT contour wheels, Raceland coils, Halo Headlights
Trev FF is offline
Old 03-16-2013, 06:05 PM   #17
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
I make and sell the VCT Elim so you can run a regular adj cam gear
I never said the rev lim was set to 6250 just that it should rev to 6250 with no problem
There is no gain from adding a zx2 head to the Focus , the valve springs are the same in both heads unless you have a hydrolic cam zx2 head
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-31-2013, 12:47 AM   #18
JOERUSSIA
Fan#: 112595
What I Drive: 1998 ford contour
FF Reputation: 1 JOERUSSIA Good Standing Member
Does anybody know if 00-04 zetec heads will fit on a 98 zetec?
JOERUSSIA is offline
Old 03-31-2013, 04:49 PM   #19
JOERUSSIA
Fan#: 112595
Do you guys know if i can put 2000-2004 focus parts on a 98 contour?
Old 04-01-2013, 02:20 PM   #20
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
Depends on the parts but the head should fit with no problem , you will need a tune to turn off the cam sensor and VCT because you will leave it unhooked
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
