2.0l to 2.3l head swap - Page 3 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > DURATEC Performance (2003-2007)
Old 02-28-2013, 05:34 AM   #21
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
Honestly you're not going to see any noticeable gain. You would be better off polishing the intake ports and running a better set of camshafts.
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 03-09-2013, 08:29 PM   #22
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
I'm with you on this head swap mod for N/A apps. Ford did not install a smaller port head on the 2.0L to make it inferior. It was done to better match the head flow to the cam, to optimize powerband, output and efficiency. The bigger head belongs on the 2.3 or on a 2.0 with cam swap to raise the powerband. It's wrong to assume that a head swap will lead to 2.3L powerband or similar peak horsepower. The 2.3L is about 15% larger displacement and this is what makes it about 15% more powerful. It's not the head flow doing it.
Lscman is offline
Old 03-09-2013, 11:47 PM   #23
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 52 felixthecat Great Standing Member
Yes I agree w/ you. ^^^^^ I'd just throw a 23 on board. Mazda's MX-5 is a 20 w/ 170 hp. I'd bet they are using a 23 head. The head on the 20 foci has smaller ports for velosity= air flow, for the shorter stroke. Its not like a lot of regular joes are driving MX-5's.
felixthecat is online now
Old 03-11-2013, 08:14 PM   #24
Lscman
Fan#: 95211
Yea the higher horsepower MX5 2.0 motor probably has higher flow heads mated to a more aggressive cam grind. This pushes the powerband upstairs and keeps it broad, instead of killing the bottom end with oversize ports and killing the top end with a wheezing cam profile.
IMO, big heads with stock cam is a total loser....just like a bigger cam mated to putzmobile econobox ports (optimized for low end).
Lscman is offline
Old 03-12-2013, 12:44 AM   #25
Stangbanger242
Stangbanger242's Avatar
Fan#: 68740
Location: Bolingbrook (and sometimes Hamilton,ont,Canada), IL
What I Drive: 09 Black SES MTX
FF Reputation: 3 Stangbanger242 Good Standing Member
So correct me if I'm wrong, but the only way to take advantage of the 2.3 head swap would be to get a set of cams and a tune?
SES#010
HAVE: '09 SES MTX W/ FSWerks CAI, FSW 4-1 header, Crower Stg 1, 1.5" FRPP drop, Massive Toe arms, EBC slotted rotors + green pads.
WANTS: FSW Stealth exhaust, Tune, (possibly) Turbo
Stangbanger242 is offline
Old 03-12-2013, 03:48 PM   #26
felixthecat
Fan#: 80663
If your installing a 23 head, I'd add a set of basic DD cams, a header & a tune. You'll have the head off anyhow, so whats a 1/2hr to swap cams?
Old 03-12-2013, 04:30 PM   #27
jugglethese
jugglethese's Avatar
Fan#: 108852
What I Drive: 2007 focus gloss black SAP zx3
FF Reputation: 1 jugglethese Good Standing Member
after reading all this it makes sense now. i just bought my obx header, typhoon cai, and the sct from tom. should be coming in this week or next :) i figure if i can find a 2.3 for cheap ill be able to buy cams in a month possibly, then im going to try this out. but by putting the 2.3 head its going to lower my compression?
jugglethese is offline
Old 03-13-2013, 11:02 AM   #28
felixthecat
Fan#: 80663
So whats you going to do?
Old 03-13-2013, 08:41 PM   #29
Lscman
Fan#: 95211
Yes.
Bigger ports mated to small stock cam and small displacement will only serve to produce a narrower powerband than stock. The few extra horsepower you gain on the top end will be offset by horsepower losses in the middle. Power near the bottom end of the power curve will be seriously reduced. The net result will be no additional usable power under the curve; that is, it's a big waste of time and money. The car will feel more peaky (and perhaps more impressive to some) due to narrower powerband, but it will not be faster. You will have to row the shifter more precisely just to stay in the powerband. Who in the heck wants that? Not me.
Lscman is offline
Old 03-13-2013, 09:48 PM   #30
felixthecat
Fan#: 80663
Simple answer= velocity, is your friend. in & out stuff.
