Sounds in the front end on 2008 SES - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2013, 09:03 PM   #11
Red Jay 918
Red Jay 918's Avatar
Fan#: 79277
What I Drive: 2010 Focus SE
Points 9,442, Level 65
Points: 9,442, Level: 65 Points: 9,442, Level: 65 Points: 9,442, Level: 65
Level Up 31% Completed
FF Reputation: 7 Red Jay 918 Good Standing Member
couldn't make out much but sounds like a bearing IMO. jack her up in neutral & spin the fronts... if you hear a low growling noise from either than that just could be your culprit. i learned yesterday a wheel bearing doesn't need to have play in it to be toast..
Red Jay 918 is offline
Old 03-07-2013, 12:22 AM   #12
steveandbelinda
Fan#: 109959
What I Drive: 2008 Blue Focus SES
FF Reputation: 1 steveandbelinda Good Standing Member
I did that about a week ago, and didn't feel or hear any noise or drag.
steveandbelinda is offline
Old 03-07-2013, 10:27 AM   #13
steveandbelinda
Fan#: 109959
Well, wasn't the tire. New tire and still making noise, so out we go to start on the left side dismantle project. Probably will do both hub assembly kit and cv shaft, then see if we still have noise.
UPDATE: Put car on jacks and had someone sit in the car with it running and in drive. Had them just let it idle in drive. Left wheel moved a little then quit spinning, but right side continued to rotate. Sound started but with ear close to tire could not hear that the noise was coming from wheel bearing. Standing in front of car I could hear the noise quite easily and also the grinding noise was also obvious. Put piece of pvc up against mid bearing on right shaft and could hear some noise but that could have just been engine noise. So I guess I will change the cv shaft and might as well change bearing and hub assy while I am in there. Will take pics and put together a thread on what I did, when I am done, so that others may see what they are in for.
PS Does anyone know if trans fluid will come out when I pull the shaft out?
Old 03-11-2013, 04:54 PM   #14
steveandbelinda
Fan#: 109959
Replaced right cv shaft, and new wheel bearing on right side. Noise is gone. As soon as I put a short tutuorial together, I will post on Youtube and put the link here for other to see.
