MFT 3.5.1 bugs - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-27-2013, 10:42 AM   #121
slybarman
Fan#: 105425
Points 1,664, Level 23
Level Up 64% Completed
Originally Posted by Bigbot45 View Post
This is happening to me now after a remote start. So the car may have been running for 10 minutes. Also, this didn't happen at all for the first few months of this update; but is now happening all of the time. I'm beginning to wonder if perhaps the battery is becoming marginal; since the only other time I would see this behavior is after the MFT restarted.
Also, talk about bad updates, I tried to do this in my wife's Edge and the MFT suffered terminal hardware failure. After it said it would re-boot the screen went black and never came back up. The APIM is hopefully being replaced today.
MFT does not boot during remote start. It only boots once you get into the car, put your foot on the brake, and press the start button.
slybarman is offline
Old 02-27-2013, 12:55 PM   #122
Bigbot45
Fan#: 87124
What I Drive: 2014 Q50 - Formally 2012 Ti Hatch
Points 488, Level 9
Points: 488, Level: 9 Points: 488, Level: 9 Points: 488, Level: 9
Level Up 76% Completed
FF Reputation: 2 Bigbot45 Good Standing Member
I have a Viper remote start and the MFT comes on-line as soon as the remote start is engaged. Also the Viper has a proper remote start->key handoff so the car never shuts off when you get in.
2012 Ford Focus Titanium Hatchback
2006 VW Jetta 2.0 Package 2 <-- 2001 VW GTI VR6
1990 Subaru Legacy <-- 1986 Ford Taurus
1990 Mazda Protege <-- 1986 Subaru GL-10 Turbo
1986 Volvo 240 DL
Bigbot45 is offline
Old 02-27-2013, 01:08 PM   #123
slybarman
Fan#: 105425
My OEM remote start does not shut off when I get into the car.
Sent from my Galaxy Note 2 using FF Mobile.
MK3 Focus = a lot of good ideas rather poorly executed.
Old 02-28-2013, 08:21 AM   #124
lewisra
Fan#: 93289
Points 1,431, Level 21
Level Up 31% Completed
Same with mine. MFT also boots up when remote started. I don't have push button start though.
lewisra is offline
Old 02-28-2013, 07:33 PM   #125
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
My OEM remote start boots up the MFT and I have the push button start.
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 02-28-2013, 08:06 PM   #126
slybarman
Fan#: 105425
Weird - I just tried mine again to make sure my memory was right - my small dash screen says "remote start active", but the MFT screen is off until I get in and hit the start button.
Old 03-01-2013, 09:02 AM   #127
copernicium112
Fan#: 87742
Points 1,491, Level 21
Level Up 91% Completed
Likewise. I also make it a point to shut off the stereo before shutting down the car during winter since there is no point in having music playing during a remote start but on some random occassions the car takes the liberty of turning it back on. I haven't really quantified it but if I had to guess, I'd say about once for every 10 or so starts.
copernicium112 is offline
Old 03-01-2013, 09:31 AM   #128
slybarman
Fan#: 105425
I wonder if the behavior of the remote start / MFT changed from the '12 models to the '13 models.
Old 03-11-2013, 02:42 PM   #129
hillcountryflt
Fan#: 110945
FF Reputation: 1 hillcountryflt Good Standing Member
Sync VersionGen2 - V3.5.1
The only oddities I am experiencing right now is that occasionally the audio input will be different from when I turned the car off previously. While not sure if this related to my sync or not, my backup camera will "lose" its guidelines (active or otherwise) frequently between restarts.
as to voice commands, I can tell it to turn climate on, turn a/c on and set temp and it will respond affirmatively, but nothing is actually working. I actually (heaven forbid) have to press the "soft" button to actually get it to start functioning. When it comes on, it will be a/c on and temp set to 70 as previously instructed during sync commands.
2013 Ford Focus HB Titanium
2011 Ford Mustang
hillcountryflt is offline
Old 06-24-2013, 01:27 PM   #130
WebNutMark
Fan#: 97795
What I Drive: 2012 Blue Candy Titanium
FF Reputation: 1 WebNutMark Good Standing Member
Persistent bugs I've noticed:
I generally use the MP3/USB for listening to music in the car...
When parking for less than 5-10 minutes and then restarting the car, the media index is lost nearly every time (probably 75% of the time). If parked for longer periods, it happens much less often.
When starting the car while it is in accessory mode (shut off car - continue listening to radio and not open door - then restart the car) the input will switch from USB to A/V (probably 90+% of the time).
WebNutMark is offline
