Require detailed information on dual clutch transmission - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-10-2013, 07:03 PM   #21
Hodge Podge
Hodge Podge's Avatar
Fan#: 96120
What I Drive: 2012 5-Dr Se Sport Pkg Ingot Silver
FF Reputation: 1 Hodge Podge Good Standing Member
I suspect Ford has there reasons for going with the Motorcraft DCT Fluid 2 XT-11-QDC, and I'm sure economy was one of them. On the other hand, I doubt we'll ever see any transmissions that fail sooner as a result of that decision than if Ford had used a thicker, traditional gear oil.
The focus is a relatively light vehicle powered by a relatively low-torque engine, so the DCT simply won't be subjected to the high-torque and/or heavy load conditions that would warrant a thicker, more viscous fluid. Super Duty trucks and larger for example, may require a thicker transmission fluid for various reasons, but realistically, it's overkill to use that thick a fluid in the focus. (It'd be like running straight 40 or 50w oil in the engine when 5w20 is more than adequate in almost all scenarios)
As a side note, the 5-speed manual in my 1/2-ton Silverado runs GM Synchromesh fluid which, like the Motorcraft Dual Clutch Transmission Fluid2 XT-11-QDC, is closer to water or WD-40 than it is gear oil. 247,000 miles later, it's doing just fine.
____________________
Hodge Podge
2012 Se Ingot Silver 5-Door w/ 201A & Se Sport Package
2001 Silverado 1500 RCLB 4x4 4.8L 5-Speed
Hodge Podge is offline
Old 03-10-2013, 08:29 PM   #22
PandT
Fan#: 110640
What I Drive: 2013 Titanium Hatch 18" Plat White
FF Reputation: 2 PandT Good Standing Member
I'm sorry but, I would like to see what the differences are and why they chose a different fluid. - manual verses automated manual when the clutches are not involved. I assume they have a reason and I would like to know what it is, it may be important concerning the internals, materials change, lubricity on those materials, corrosion, wear...
WHY the difference? That is the question.
2013 Titanium HB - Handling pkg. - Platinum White
PandT is offline
