Exhaust specs - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2013, 09:49 PM   #1
Artplata
Fan#: 108806
What I Drive: 2012 Silver Titanium
FF Reputation: 1 Artplata Good Standing Member
Exhaust specs
I have been doing research and wanted to get forum's opinion regarding cat-back exhausts. From what I have gathered all exhausts manufacturers have increased the stock size pipe to 2.25 inch diameter pipe adding their muffler and an exhaust tip to top it off. I was wondering if you have these local Mexican muffler shops just install a 2.25 diameter pipe just from cat to muffler, would that make a difference. Why would these companies charge so much for their product if these local shops can meet their specs at a fraction of the cost.
Your opinion is highly regarded, thanks in advance.
Sent from my SAMSUNG-SGH-T989 using Xparent Cyan FF Mobile
Artplata is offline
Old 03-06-2013, 10:01 PM   #2
Points 10,261, Level 67
Points: 10,261, Level: 67 Points: 10,261, Level: 67 Points: 10,261, Level: 67
Level Up 53% Completed
Forum Activity 37%
The higher quality aftermarket kits use mandrel bent stainless steel tubing vs crush bent steel/ iron/ non stainless steel/ aluminized steel tubing that your local exhaust shop would usually use which constricts the flow at every bend and would be worse than stock.
If you can find a shop that has a mandrel bender and can use good quality stainless pipes it might be ok, but most just use the cheap tube benders that crush or crimp the pipe in the process.
suss6052 is online now
Old 03-06-2013, 10:38 PM   #3
Jim_J
Jim_J's Avatar
Fan#: 109775
What I Drive: 2013 Silver SE with a shudder trans
FF Reputation: 1 Jim_J Good Standing Member
In Vegas aluminized steel will likely last the life of the car, so paying for stainless might be pointless.
Enough 2.25" stainless to do the exhaust would cost close to $200, or more retail, plus $150 for the muffler. 2.5" Aluminized steel would be $50 plus $100 for the muffler. Add labor and you can probably still beat that $650 plus labor magnaflow cat-back price, get dual out if you want, and support your local working stiffs.
Mandrel bends are better, but 2.5" crush bends would suffice I would think, especially with the cat in front of it.
That being said shops with mandrels are not that hard to find, there is at least one here in SD, probably one in vegas as well.
Jim_J is offline
Old 03-07-2013, 12:00 AM   #4
Sean05
Sean05's Avatar
Fan#: 62491
What I Drive: 13' ST2
Points 1,627, Level 23
Points: 1,627, Level: 23 Points: 1,627, Level: 23 Points: 1,627, Level: 23
Level Up 27% Completed
FF Reputation: 5 Sean05 Good Standing Member
my se sport had 2.25 piping in most of the exhaust....
After asking a friend with 07 sedan if he wanted to race " I'm gonna loose! Mines not a zx4!! "
Sean05 is offline
Old 03-07-2013, 01:11 PM   #5
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
Points 4,361, Level 42
Points: 4,361, Level: 42 Points: 4,361, Level: 42 Points: 4,361, Level: 42
Level Up 6% Completed
Forum Activity 6%
fswerks is 2.5"
darkangelism is online now
Old 03-07-2013, 01:21 PM   #6
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,822, Level 76
Points: 13,822, Level: 76 Points: 13,822, Level: 76 Points: 13,822, Level: 76
Level Up 44% Completed
Forum Activity 100%
If all your looking for is a different tone of noise= Why not just add a different muffler?
^^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^^^^^
^^^^^^^^^^^^^^^^^This is what you have^^^^^^^^^^^^^^^^^
Originally Posted by darkangelism View Post
fswerks is 2.5"
If you want to get a desent quality system, here you go. ^^^^^^^^^^^
felixthecat is online now
Old 03-07-2013, 01:48 PM   #7
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Points 4,224, Level 41
Points: 4,224, Level: 41 Points: 4,224, Level: 41 Points: 4,224, Level: 41
Level Up 37% Completed
Crush bent or mandrel bent has negligible horsepower diff on a naturally aspirated car. As long as you keep the bends to a mild degree you'll get pretty much the same results for cheaper unless you are squeezing every bit of HP you can get then spend some money.
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 03-07-2013, 02:47 PM   #8
Artplata
Fan#: 108806
The shop near my home will do a 2.5 inch pipe from cat to muffler for $120. I intend to keep muffler for now. Is it worth the spend?
Artplata is offline
Old 03-08-2013, 01:54 AM   #9
Jim_J
Jim_J's Avatar
Fan#: 109775
That's a question only you can answer. The real restriction on this exhaust is the cats, and everything I have read leads me to believe the engine responds better to intake mods than exhaust. I would save up and replace the muffler as well all in one shot.
Jim_J is offline
Old 03-09-2013, 01:01 AM   #10
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
I'd pass & put the $ some where else. Intake or suspension.
