Oil Pressure concern/question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST EcoBoost Performance (2013-Current)
Focus ST EcoBoost Performance (2013-Current) The place to chat about the 2.0L EcoBoost engine performance, tuning and exhaust related upgrades.
Old 03-02-2013, 07:49 PM   #1
shineboy
shineboy's Avatar
Fan#: 60173
What I Drive: 2013 ST, 2004 Cobra
Points 1,216, Level 19
Points: 1,216, Level: 19 Points: 1,216, Level: 19 Points: 1,216, Level: 19
Level Up 16% Completed
FF Reputation: 1 shineboy Good Standing Member
I think my oil pressure runs low... so I am running Motocraft 5W30 synthetic blend with a Motorcraft filter. Assuming the gauge numbers are right it runs about 52-70psi cold under load depending on temperature, at hwy speed (at temperature being close to 200) seems to be about 18-20psi first mark, at idle about 9 psi (at temp). I added a pic so you can see where on the gauge I am talking about.
I am curious of what pressures you guys are seeing?
2013 ST2 for DD
2004 Terminator for fun
shineboy is offline
Old 03-03-2013, 12:55 AM   #2
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2014 Tuxedo Black SE Sport
Points 1,566, Level 22
Points: 1,566, Level: 22 Points: 1,566, Level: 22 Points: 1,566, Level: 22
Level Up 66% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
FF Reputation: 5 StingRay Good Standing Member
Mine is almost exactly the same as yours, per the marks. I thought it was a little on the low side as well, but It was fine off idle and didn't set a light so I haven't worried too much.
StingRay is online now
Old 03-03-2013, 01:42 AM   #3
thejordan
thejordan's Avatar
Fan#: 107706
Points 1,041, Level 17
Level Up 41% Completed
high pressure at cold is normal.
normal warm operating pressure is 29-60psi.
warm idle should be around 15-20psi.
it will obviously vary while driving in addition to turbo usage.
i think you can put the st into test mode and read the actual pressure from obd2.
thejordan is offline
Old 03-03-2013, 06:31 AM   #4
shineboy
shineboy's Avatar
Fan#: 60173
How do you put it in obu test mode. I remember holding the odometer reset on my old SVTF to get to some sort of diagnostic. I also have a SCT tuner, I will see if that can see oil pressure.
My actual concern is I just had the dealer do their complimentary service, prior I am pretty sure the numbers were higher. Wondering if they out 5w20 in itů
2013 ST2 for DD
shineboy is offline
Old 03-03-2013, 02:13 PM   #5
thejordan
thejordan's Avatar
Fan#: 107706
You have to modify your SCT tuner with some files to get livewire working. Again not sure if the SCT will be able to read that information either. The dealer will be able to though.
To put into test mode, hold the left steering wheel Ok button, keep holding, turn the key to the 2nd accessory on position, keep holding until the message pops up on the screen, hit ok. I'm not sure what data it will give you though once you enter test mode (once in test mode you can start the engine).
Your dealer receipts should say what oil they used, or call them and ask for a new copy. I don't think anyone can be that stupid to put the wrong oil in.
Do you mind taking a pic of the gauges at warm idle?
Old 03-03-2013, 09:06 PM   #6
shineboy
shineboy's Avatar
Fan#: 60173
cold start
55mph 6th up to temp
idle at temp... sort tough angle lower than it looks, 2/3 to first line
2013 ST2 for DD
shineboy is offline
Old 03-03-2013, 09:18 PM   #7
StingRay
StingRay's Avatar
Fan#: 67421
Forum Activity 34%
No joke, those are exactly where mine sit. Its probably fine
Old 03-03-2013, 09:34 PM   #8
shineboy
shineboy's Avatar
Fan#: 60173
Thanks but damn I swear they have been consistently higher. I probably just need to pay more attention to my gauges.
Still think 12-15psi at idle seems a little low, then again I have no idea what it should be. I will have to do a little reading.
2013 ST2 for DD
shineboy is offline
Old 03-05-2013, 12:34 PM   #9
thejordan
thejordan's Avatar
Fan#: 107706
Still think 12-15psi at idle seems a little low, then again I have no idea what it should be. I will have to a little reading.
looks good to me.
Old 03-05-2013, 09:38 PM   #10
spinadog
Fan#: 108381
What I Drive: 2013 Focus ST3
FF Reputation: 1 spinadog Good Standing Member
confirmed - I see the same readings. My car is also white - could that explain it? :-P
spinadog is offline
